Spitfire Spitfire MK2 calipers
mharrelll311
I was wondering if anyone has put new MK3 calipers on their MK2. I have been having some real trouble finding a cheaper set of calipers that originally came on the car, but there are MK3 calipers that can be had for about $40 online. Anyone had any trouble switching out these?
tomgt6
It should work. The vertical link is the same on the mk2 and mk1 after this number from what I can see from a web site. Here is what it says.
VERTICAL LINK LH MK1SPIT from FC15,576 and all MK2-MK3 SPIT
mike_h
Member
I've had a couple of Spits, from a 63 to my wife's 80 1500 and I interchange brake calipers, have a few sets in storage, all the time. Sometimes you'll need to shim the caliper to keep the disk centered, depends on the disk. Just have an assortment of washers ready, different thicknesses, and slip them in between the upright and the caliper (around the mounting bolt).
mike
JKB1957
If you want to keep the car original I would contact Scott Harper over at Team Triumph. He should have a set. Or as everyone else has said the calipers are interchangeable between Spitfire models, so you have choices.
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
C Wanted triumph spitfire mk2-3 drivers seat bucket Triumph Classifieds 0
L Spitfire 1965 Triumph Spitfire MK2 Triumph 4
JRC Spitfire 1965 Spitfire Mk2 - Colorado Triumph 107
T Spitfire Spitfire top install mk1 or mk2 Triumph 2
G Spitfire mk1 mk2 spitfire clutch conversion ?'s Triumph 7
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
