Deleted member 8987
I've worked on vehicles hobby and professionally for 45
years. Worked on more British cars than I can remember. But
I've come across something I cannot seem to figure out.
My MK2 was poorly maintained (gas station) for 30 years.
Brakes was one of the issues.
So, I had the master re-sleeved and rebuilt. All new
flexible hoses. Cleaned out the reservoir, new float
assembly, new line from reservoir to master, new line from
master to servo booster, couple of other steel pipes, new
calipers front (had the wrong sized pistons), rebuilt rear,
new pads, then the PBR (Australian) power booster
rebuilt....and continuously got air in the servo cylinder.
Played with it for about a year, you'd know, as the pedal
got a tad ''mushy'' at the top. No big deal, crack the bleeder
on the servo, wait until the air was gone, good to go for
another month.
Rebuilder in Melbourne couldn't figure it out, so sent the
cylinder and pushrod back, he went through it again
(different cylinder came back), and it's been fine. High
firm pedal, good boost, no issues.
Saturday morning, drove it to St. Arbucks, no problem,
parked it till this morning.
On the way to St. Arbucks, geez, pedal a tad low, a little
soft, no warning light. On the way back, complete loss of
brakes. As in, pedal to the floor. Pumped a couple of times,
nothing, crept home (couple of blocks) on e-brake. Reservoir
full, right where it's been all this time. Cracked the servo
bleeder...air. Let it evacuate, pumped a couple of times,
re-bled, no more air, works good, drove it, back to her old
self.
I have never seen air work it's way to a low point like
that. If the master is letting air in (my experience is that
is quite common when they start to go, being almost
vertical), it won't migrate downhill to the slave. Since
it's not using any fluid, and nothing is damp, I am just
throwing this out there.....I am now adding a weekly servo
bleed to maintenance. Odd.
Thanks
Dave
another month.
self.
Thanks
Dave
