Weber carb and possible vacuum hose
DarwinT
DarwinT
Member
lbc_newbie said:
That's the vacuum advance for your distributor. Now, I've been told, that with the Weber set-up, it might not be necessary. I know someone on the Forum here will clarify that for us Weber guys.
:bow:
My vacuum advance is hooked up to the intake manifold.
DarwinT
DarwinT
Member
lbc_newbie,
My vacuum advance hose is hooked to the intake manifold and nothing is hooked to the thing on the carb. If both are equal vacuum sources, I should plug up the unused one, right? And then re-adjust the carb.
I can't start it right now because I have the exhaust off. I got my Harley muffler today.
Roger
Bronze
I know little about Webered Midgwets, but in my experience it's unusual to connect vacuum advance to the inlet manifold, but rather to the carb. They are not, to use your expression, equal vacuum sources.
For example, on closed-throttle overrun, you have maximum depression in the manifold. Do you want maximum advance under that condition? Probably not!
DarwinT
DarwinT
Member
That's what I thought! I assumed the guy that sold the car to me knew what he was doing - he had built two dragsters which are stored in his barn. He isn't physically able to drive them any more.
I'll change the vacuum line to the carb and plug off the one to the manifold then.
Thanks.
jvandyke
maybe you can use the manifold source to help with crank case venting, made a world of difference on my Weber equipped 1098 (BTW I don't remember where my vac adv. line hooks up, pretty sure carb base, but I'm going to look now)
bthompson
I have my distributor advance disconnected entirely. (Weber carb, 45D dizzy.) I think I got the tip from John Twist: just make sure the mechanical advance maxes out at 32 degrees BTDC, and let the idle timing fall where it may. I'm <span style="font-style: italic">way </span>off of the recommended 2 ATDC idle this way, which causes some hard starts when it's cold. Not the ideal solution, but it runs well enough.
regularman
That tube at the bottom of the carb comes before the butterfly in the carb IIRC. and gives vacuum when the throttle is opened, but very little at idle. The intake vacuum would be just the opposite with the vaccum at max at idle and minimum at full throttle. I put a tap in my pierce manifold and ran it to the valve cover vent to stop the oil leaking when the engine is running and this worked great.
DarwinT
DarwinT
Member
Fixing that should make it run a lot better. I had a lack of power and vibration at lower RPMs. I had to floor it to get up to speed. That was no big deal, because I ALWAYS floor it.
I'll need to adjust the carb again. I'll start a new thread on that subject.
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
