Gulp valve, Weber carb
mylillooker
I've got a 1500 Midget in Kentucky which I got from a dead guy in Arizona whidh obviously came from California cause it has all kinds of "California only" stuff on it. My question is do I need the gulp valve if I've got the weber carb. How do I close it off if I don't and how should it be attached if I do. Something needs to be done wih it cause it's killing my power. I've plugged it and that just busted the rubber connector/grommet and created a lot of soot from the air manifold
This is what my Haynes manual says it's supposed to do...
A gulp valve is fitted, to California models only, in the supply between the air pump and the inlet manifold. It's purpose is to lean off the rich fuel/air mixture present in the manifold immedialely after closing the throttle following running at full throttle, that is on engine overrun. The valve is located on a cylinder head bracket adjacent to the oil cap.
k , i''l take a shot at this,
Since you dont have the original zenith that was designed to work correctly with the emissions and CAM in the car, you may have a tough time time getting it all together. i have a 1500 and have removed all smog equipment and replaced the cam with an uprated one. It is my understanding from reading this board that the cams were modified as time went on to meet stricter emissions imposed by the epa here in the states. in other words they were detuned and set up to work with the smog system. If parts are missing or not functioning properly, your going to have troubles.
The weber is not a bad carb, some here will disagree, i have one on mine and am fairly happy with it.
your question of whether you need it or not is dependent on whether or not you need, or want your smog system up to spec.
i have an old chiltons that shows it hooked up like you describe but with a smaller hose also connected to the intake manifold. Hope this has been of at least some help.
mark
jollyroger
You would be violating federal emission laws, but you can just romove the offending valve and plug the holes. No one can tell you to do this because it is against the law. You are already violating the law by having the Weber on it anyway, so what the heck?
jcatnite
Plus the emissions routing changed every year on these little cars...I think. I'm sure that they are all pretty much serving the same function but the components and hoses are shifted around a bit in every picture you can get your hands on. I for one have a big question mark as far as the emissions system goes.
JC
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
M Question about anit-gulp valve MG 11
J Gulp valve MG 1
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ā€˜74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
