Spitfire Spitfire 1500, setup for single Weber carb
jorg
Hallo,
I am new here in this Forum and have a question about the carb setup for a 1977 1500 Midget. (In order to reach the Spitfire owners I posted at the Triumph-Forum too.)
Does anybody know what the basic setup for a single Weber DCOE 45 for a standard 1500 engine is? The car should mostly run under normal conditions with rpm between 1500-5000 with intention on maximum fuel economy and less power output above 6000 rpm and should have smoothe idle.
The following basic setups for a single Weber DCOE 45 I found on the internet:
Choke 33
Aux. Venturi 4.5
Main Jet 190
Emulsion Tube F9
Air Jet 175
Pump 40
Idler Jet 45F9
(Moss)
Choke 34
Aux. Venturi 3.5
Main Jet 150
Emulsion Tube F2
Air Jet 175
Pump 50
Idler Jet 55F8
Accel. pump (jet) 50
Ex.Valve 50
Choke 34
Aux. Venturi 4.5
Main Jet 145
Emulsion Tube F16
Air Jet 155
Pump 45
Idler Jet 55F8
Ex.Valve 40
Thanks
Jörg
Germany
Alan_Myers
Hi Jörg,
Welcome to the forum!
I think you will find that any info you gather on this will only be a starting point. Ideally, you should find a local Weber tuner and get the car on a dyno and/or exhaust gas analyzer to have the carb dialed in for your particular car. Spitfire data might not translate very well to an Midget installation, even though the basic engine configuration is the same. There are a lot of other possible variables (manifold design, valve sizes, exhaust system efficiency, emission controls, local tempertures and humidity, etc.) that effect any Weber DCOE installation.
Also, DCOE are not likely to give the best fuel economy. They are widely known to do just the opposite (some Weber downdraft carbs are more economy-oriented). One reason is the DCOE's accelerator pump, but you can play around with setting that up for a little improvement in fuel economy.
That said, I looked up to see what I could find in my Weber tuning manuals. The manuals I've got don't list the Mk 4 Midget, just the Mk 3 with the 1275 engine. They also don't list any Spitfire installations at all.
For the 1275 engine, the following is the recommended starting point:
45DCOE13
Choke 34
Aux. Venturi 3.5
Main jet 1.30
Emulsion tube: F2
Air correction jet: 1.75
Idle jet: 050 F9
Accel. pump jet: .50
Accel. pump inlet: .50
(needle valve: 2.25)
I notice this is nearly identical to your 2nd choice. Just judging from the additional engine size, I would think your 1st (Moss) choice might be closer.
Something to try is contacting Pierce Manifold here in Gilroy California (www.piercemanifolds.com). They are Weber specialists and might be able to give you more specifics.
Another possible source of info is Advanced Performance Technology, also in California, (www.aptfast.com), which is a Spitfire/1500 Midget specialist and offers Weber carb conversions.
Another Spitfire specialist is Performance Research Industries in Oregon (www.prirace.com), however their focus is not on Weber carbs, in general. They adapt other types of carbs for use on Spits.
Your goal to keep the car in "street" tune is certainly possible. I've run Weber DCOE on my TR4, primarily a street car, since the 1970s. One way to achieve street manners with DCOE is to keep to slightly smaller size chokes and then jetting to best accommodate those.
Hope this helps and that others jump in with some suggestions.
billspit
I have no experince with the Weber on the Spitfire or Midget, but have read the single carb set up is not the best designed system. The two carb set up is better. I assume you have a higher compression engine than we would have in the US and possibly a more agressive cam. That is ggod. Otherwise bolting a weber onto a standard US spec car isn't likely to result in much pleasure. As Alan says, you really need a dyno to adjust the carb correctly.
G Spitfire Spitfire 1500 differential whining Triumph 6
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
F Spitfire Spitfire 1500 Dash Lights Triumph 1
W Spitfire Spitfire 1500 Steering Column Triumph 3
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
Anthony_S Spitfire Spitfire 1500 for sale in my area Triumph 1
S Spitfire Is a 1973 spitfire a 1500 or a mark IV? Triumph 7
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
F Spitfire SUs On a Spitfire 1500 Triumph 14
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
F Spitfire 77 Spitfire 1500 Questions Triumph 3
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
mikecyc72usa Spitfire First Autocross in my Spitfire 1500 Triumph 29
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
K Spitfire 60’s spitfire body swapped onto a 1500 cassis Triumph 3
M Spitfire Spitfire 1500 OD transmission Triumph 9
A Spitfire Triumph Spitfire 1500 Triumph 8
K Spitfire Spitfire Mk IV tonneau =Spitfire 1500 tonneau? Triumph 2
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
pjsmetana Spitfire Spitfire 1500 TC Triumph 2
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
1965_MGB Spitfire Junkyard Find, Spitfire 1500 I think Triumph 6
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
