Weber Carb meets hood...
als
This is a problem I have had since I got my 76 Midget a year and a bit ago... the air filter top cover on the weber carb which was installed on the car(DGEV)rubs on the underside of the hood to the point where it has made a dimple on the hood.
The mechanics who work on my car (I know, I'm a wimp, but I know my limitations) tried shaving off a corner of the top plate...didn't help... I tried shaving off more... made it worse.
I have now put a spare filter cover on so I am back where I started.
I know that many Midgets have Weber DGAVs installed and because I have seen no one else whining about it, I have to assume that my problem is not usual.
I cannot see any way I can fix this so I am looking to all of you with your vast experience to offer the magic solution.
Thanks in advance
Al /ubbthreads/images/graemlins/canpatriot.GIF
Mine rubs a very little also. i switched to the rounded style aircleaner, seemed to help. also try checking the up/down hood alignment, perhaps your rubber stops are worn or missing. there should be one on each side.it is a tight clearance
mark
A
als
SU (Is that a coincedence or a pun?) I have new rubber stops, and have adjusted the hood alignment to eliminate the rubbing, but now the hood rests about 3/8" above the fenders on each side at the front.... I am contemplating taking off the carb and intake manifold and having the carb mounting plate on the manifold ground off by as much as can safely be done. This will lower the whole carb by whatever that amount is.... good idea?...BAD idea????
Thanks
Well the truth be known i have had the name much longer than i have had my LBC's. It wasnt till i joined this Forum(the Best Forum on the Planet) that some one used the initials. it never even dawned on me till that day, but i think its kinda cool..
I wouldnt think you would have to deck the manifold, dont see where it would hurt anything if you did. perhaps you engine isnt fully seated on the mounts, are they new? there are pins to align the intake manifold, perhaps they were miss drilled, or are not there. I take you dont think you hood is tweeked or slightly warped. also there should be some shims between the hood and the hinges. perhaps reshimming there may help....just some suggestions. Keep us posted
Mark
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
