Weber 32/36 DGEV Carb
pjsmetana
I got one of these on my 1500. I did a few archive searches and found
the Weber Troubleshooting Guide
https://www.webercarbsdirect.com/v/vspfiles/images/Weber%20Trouble%20Shooting%20Guide.pdf
and a site with Weber Carb setup and idle adjust
https://www.carburetion.com/Weber/adjust.htm
But what I didn't find, was anything to do with choke cable adjustment or much to do with vacuum.
This is my 1st engine with a manual choke, and also my 1st Weber carb. So, I can't say I know much about it at all right now.
The issue is, when warm and at idle, I have to keep the choke cable pulled out about the thickness of a nickle to keep the idle at 800ish RPM and fairly smooth. It runs like a scared cat like this till about 4500 RPM then there's a nice little power drop off. I have not taken it over 5000 RPM, not that I really want to, just thinking of things that may help figure out my issue. If I push the choke cable all the way in it Idles about 600-700 RPM and really really rough, but does not stall, and is still great on throttle response. Following the Weber Trouble Shooting Guide, it talks about vacuum being the problem. I've never had any automatic tranny cars, any vacuum retard/advance distributors, or really anything that had much to do with vacuum. My previous VW engines all had centrifugal advance dizzys and temp controlled chokes, and all my Honda's were FI and electronic/computer controlled.
Anyways, I guess this is a 2 parter. Can someone school me, or point me to what to read on vacuum... and is it possible that my choke cable is pushing the choke back to partially closed when all the way in, thus only needing a minor adjustment?
I suppose if I was home I could go out and play with all this stuff hands on, but bored times call for lots of reading and the mind wonders.
Btw, I have no idea what cam is in this thing and the PO didn't either.
Thanks guys!
71MKIV
Definitly sounds like your idle is set a tad low. 8 to 900 is where mine is set. Skooch your idle up a bit. My DGV has a vacuum port on the side for the dizzy. Since my distributor is strictly mechanical the port has a cap on it. I will see if I can get a picture of it tonight.
The 4500 rpm power fall off sounds like a stock head. Port and polish will help that.
The choke flaps have a stop at wide open, I don't think that's the issue. I really think that you just need to set your idle up to 825 or so. I will definitly try for pictures tonight, depending on what my SWMBO has on the docket.
pjsmetana
pjsmetana
Now to adjust this on this carb, is it the Fast Idle Screw, Primary Idle Screw, or the Idle Mixture Screw?
Bottom of the last page on my 1st link if you don't know which is which. Not a very good picture though...
71MKIV
You want the primary idle screw. Don't go messin with the idle mixture just yet. Just turn the screw in until your idle is between 850 and 900.
Dan76spit
im having an issue with my weber also but my idle is the other way. It set at about 1100 or so and runs pretty smooth and when I try to bring it down it gets rough. I think mines a timing issue also as im not sure if my timing needs to be altered since i have a mallory dual point and a weber dgv. I would bring your idle up first and than see where to go from there.
71MKIV
Pitchers are in the camera, now I just gotta get em in the computer.
kodanja
Ive got duel 32/36 dvg's on my Tr6
I had them rejetted and my Idle is set at 750rpm's
my timing is set about 10* adv.
she running very well with them....a little rich but she likes it that way!
kyreb1862 Weber DGEV Hook Up MG 0
S Weber 32/36 DGEV install instructions MG 2
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
T Problems disassembling a Weber side-draft DCOE Spridgets 2
T Identifying vintage of a Weber DCOE Spridgets 4
T Weber for a 1275 cc engine? Spridgets 6
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
krswen Comparing Weber kits .... advice sought Jaguar 4
DanLewis Weber 40DCOE - Does it need a check valve in the fuel supply line? Spridgets 4
DanLewis Side draft Weber and smell of gasoline? Spridgets 3
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
W Weber/stromberg air cleaners Jaguar 3
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
B Weber DGV Spridgets 2
TomChar Weber MCHH carbs Triumph 23
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
