MGB Tappet breather to Weber downdraft
Celtic 77
I have a 77 B with a Weber downdraft and am trying to organize the multitude of various hoses. There is a clear plastic line from the tappet cover to the Weber. When i take the air cleaner off, there is a lovely mist of oil that I assume is being sucked into the carb to reburn. Is this necessary? Too bad this mist couldn't have been redirected to the rocker panels! Final question: There is a water line from the rear of the cylinder head to the heater pipe that I assume was for the old Zenith. I want to use either as rubber plug on each end since it seems to be just redundant. I will ultimately have one straight heater pipe from the heater to the radiator hose. Thoughts?
Joe Reed
That hose from the tappet cover to the air filter was originally used with a PCV valve - which doesn't exist with the Weber - to provide a slight vacuum to reduce pressure in the crankcase. As you've found, most Weber users plumbed it into the air filter to hopefully still provide at least a bit of negative pressure. Inside that front tappet cover is a steel-wool type of matrix that is supposed to separate out the oil vapor, allowing it to drain back into the engine. If you're actually seeing an oil mist at the carb either that matrix is missing or, more likely, you're getting too much pressure into the crankcase via worn piston rings.
You can replace that heater hose with one going direct from the radiator hose to the heater and eliminate that small hose, which was used in conjunction with the water choke on the original ZS. Sounds as if your Weber is not equipped with a water choke. You can do what I did....remove the two screws from that fitting on the rear of the head, used that as a pattern to make a simple blanking plate and gasket and install that on the head.
Celtic 77
Celtic 77
Excellent help. Thanks for that. Great info...
Celtic 77
Celtic 77
FYI all... While shopping for door seals, I came upon Northwest Import pars in Portland Oregon. Good prices and they actually supply a blanking plate and gasket for the rear fitting on the head. $19.00! Well worth it.
Alski99
Steve at Northwest Import Parts provides great customer service. They have good prices, and fast service.
Al Hayward
ā€˜77 MGB roadster
Brooklands Green
S TR2/3/3A tappet assembly Triumph 10
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
G Tappet Noise Austin Healey 8
M TR2/3/3A Tappet Clearance confusion Triumph 3
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
Rut Brake adjuster tappet Spridgets 18
HealeyRick Rear Brake Adjuster Tappet Needed Austin Healey 2
T SPQR Tappet adjuster, Click Adjust Austin Healey 1
E Good tappet cover Austin Healey 5
L Simple fix for leaky tappet cover Austin Healey 0
T Oil leaks under carb are - tappet inspection plate Spridgets 6
memphis Tappet Tool Austin Healey 10
M TR2/3/3A TR3 Tappet Triumph 4
AH100M BN2 Tool kit spark plug/tappet feeler gauge Austin Healey 7
KVH Another Tappet Question Triumph 9
vping Tappet cover gaskets - Need help! MG 6
Baz Tappet Inspection MG 7
MadMarx Tappet - flat or domed? that's the question Triumph 5
L Tappet Inspection Austin Healey 8
V TR6 TR6 Flat Tappet Triumph 12
Wana Tappet clatter? Austin Healey 3
vping Tappet cover gaskets and.... MG 1
W TR5/TR250 TC2500 tappet clearances? Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
petnatcar Breather Hose Conversion Austin Healey 2
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
K TR2/3/3A Plugged valve cover breather Cap? Triumph 4
K TR2/3/3A Valve cover breather cap? Triumph 5
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
F TR2/3/3A Oil from Breather Triumph 3
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
gbtr6 TR6 Breather Question Triumph 5
M Bugeye breather tube re-routed Spridgets 11
KVH TR4/4A pcv valve plus breather tube? Triumph 24
MikeAH100M No Valve Cover Breather - Alloy Valve Covers Austin Healey 5
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
cbrvfr Larger carbs? Crankcase breather w/ K&N's? Austin Healey 7
D Axle breather Austin Healey 2
TulsaFred Bugeye smoking from the breather tube Spridgets 12
RedTR3 TR2/3/3A TR3 Oil Breather Mounting Triumph 6
T Breather Tube - Oil dumping in air filter and carb Austin Healey 30
PAUL161 T-Series TF Breather Hose Clamps MG 14
G Breather Triumph 5
KVH TR4/4A Oil Breather Pipe-TR4A Triumph 6
Brooklands TR4/4A TR4 Breather Pipe Triumph 8
sail Breather Pipe/Plug Triumph 13
T How do you like my custom differential breather? Triumph 13
