Brake adjuster tappet
Rut
I've converted my Bugeye to later rear brakes and I'm in need of 4 brake adjuster tappets, anyone have some in their extra parts stash?
thanks, Rut
Rut
Rut
Bill,
yes indeedy, those are them.
Thanks, Rut
dklawson
Those are the same part as used on the Mini. Mini Mania has a kit (their part number 17H7620 that includes the adjuster and two of the wedges for $19. That's a good deal when you consider that Moss sells the individual wedges (part 56) for $13 each.
Rut
Rut
Doug,
Thanks for the lead! I can't deal with $52 + shipping for a very simple part like this. I hope to find a used set and I'm not in a big hurry.
Thanks, Rut
nomad
They do wear out. Get big grooves in them that make it hard to adjust the brakes.
Kurt.
dklawson
The parts from MM are well priced as a kit but you have to pay shipping and then there is the wait time. I see you are in AL. If your experiences are anything like mine, any part ordered from CA typically takes 9 business days to make it to the east coast.
Rut
Rut
Doug,
Shipping from the west coast is only about 3 to 4 days and I'm in no rush since the car is still on the rotisserie. I'm rebuilding components in between welding and body work and brakes are on my list.
Rut
dklawson
WOW! I can only wish for that. For some reason 9 business days seems to be the average for me... at least from Mini Mania.
Billm
Rut- I found the adjusters
I'll put them in a box and wait to see if you need anything else before I send them out
Bill
Rut
Rut
Bill,
You're a lifesaver! Please let me know what I owe you and pm your address as well.
Thanks, Rut
bug_sixty
Ok, I've done this conversion.... hindsight... probably wouldn't do it again. The plumbing issues are the big pain without much gain in the braking area.... the emergency brake rod redo wasn't fun... also, careful bending of the brake line to its new position is a must. My opinion is there is so little actual use of the rear brakes its not worth the effort for everyday driving...
bug_sixty
Oh, remember from long ago.... The 1/4 and 1/2 spring hub design is slightly different too... So is the backing plates of course... This combo make's the wheel cylinder's rubber boot rub against the enter part of the hub... not good... If you do go ahead make sure that whatever year you choose as a unit you buy EVERYTHING under that design. Note, that there are quite a few design changes over the span of the spridget production..
Jim_Gruber
I just picked up 5 backing plates yesterday from a buddy in Cincinnati. One was completely loaded and simply a bolt on. Hey I now have a living /fully complete rear brake assembly I can look at for reference. 2 of the backing plates came with 2 wheel cylinders mounted on them. He told me they were from a late Spridget but I've never seen a Spridget backing plate with 2 wheel cylinders on each plate. Any idea on what they might be from?
bug_sixty
me either... I'm not a hydraulics genius so in my simple mind I went and duplicated the whole disc brake system from an early spridget unit in the BE... That being said, it wasn't all that easy or simple..... Building the better box is the 6 month deal turned into 2 yrs or longer start to finish project... Keep it simple stupid.... I have a sign in the shop to keep reminding myself!! haha
Rut
Rut
Jim,
you got me there...don't know of a Spridget with 2 wheel cylinders except for the front. I put my late brake plates on, complete with all the brake parts sans tappets, and tried the hubs I have. I Bugeye set, one '68 set, and one '73 set...they all fit well with no interference. It's close and once everything is torqued down there may be a little rub. I do have interference between the E clip and the axle and will replace them with circlips.
Rut
Jim_Gruber
It appears I have only 1 usable backplate. Got a call into local shop MG Automotive here in Dayton to see if he has anything in his "back room" I can use.
Jim_Gruber
OK looking for a set of rear backing plates from a 3/4" Disk Braked 1098 or 1275 from 67 - 74. Anyone got a set, preferably with an unfrozen adjuster screw they are willing to sell. A set with all hardware would be even better.Thanks.
Jim_Gruber
BTW, those backing plates with two wheel cylinders are for the front of a drum brake Spridget.
HealeyRick Rear Brake Adjuster Tappet Needed Austin Healey 2
Upland 69 Sprite drum brake adjuster Spridgets 7
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
Brosky Rear Brake Adjuster Rebuilding Triumph 6
K TR2/3/3A TR3 rear brake adjuster seized? Triumph 10
Brosky Brake Adjuster Failure Pictures Triumph 8
GB1 rear brake adjuster 948 Spridgets 16
DerekJ Drum Brake adjuster nut Austin Healey 5
A Rear Brake Adjuster - Manual Unclear? Austin Healey 3
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
