RE: Requesting help with identifying suspected rear brake adjuster piece?
Larry123
Found this piece below work area while rebuilding rear brake drums and rear cyl on 1960 3000. Not sure if it even is part of rebuild, but suspect it may be part of brake adjuster. Any observations appreciated.
    .jpg
BoyRacer
Re: Requesting help with identifying suspected rear brake adjuster piece?
It did not come off an Austin Healey.
andrewss
Not a standard Healey item but could have been used to secure the handbrake cable onto the chassis.. I have seen similar home made parts used for this purpose..
I don't recognize it either, but perhaps if the picture were smaller...
For future reference, I think most of the guys on here are at least middle aged and beyond (I was a KID at 24 when I bought mine, and even in 1978, most of the owners I'd meet were over fifty__some waaay over fifty) so a higher resolution image would be very much appreciated. You know, we just want to help you.
busybrit
If you found it on the floor, it likely came off a Healey !
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
T TR2/3/3A Requesting some body measurements. Triumph 10
Steve_S Requesting photos... MG 3
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
