Girling Brake Fluid Reservoir Cap
prb51
I need a Girling res cap for the 2-out can reservoir that provides fluid for the brakes and the clutch. I can't seem to find one. Moss sent me one that is the right size, but there are hardly any threads in the cap. It will not 'catch' a thread and go on. Looks like Chinese crappola.
Again, on the BN6 I do not have the individual res on each master, but the large black can with 2 outlets below. Do I need to buy from England?
Healey Nut
Try Autofarm in Canada. They get their parts from the UK.
kodpkd
Have you tried taking the big rubber thingy out and just use a plain rubber ring gasket? #582-500
prb51
prb51
The rubber seal is not in the way. The cap just does not have the proper threads; they are almost nonexistent.
kodpkd
There are two different caps Moss has. 596-211 and 596-212. I don't know the difference but maybe the other one would work. If the threads on the reservoir are bad, maybe a new reservoir. I would still try the lid without the rubber.
prb51
prb51
The 211 is for the one master with it's own res. The 212 is supposedly for the larger can with 2 out. I got the 212...it isn't my reservoir that has an issue , it has strong pronounced threads. The 212 cap is made in China and hardly has any threads at all and will not 'catch'.
It will probably work on the Chinese made reservoir they sell but I'd rather not do that.
I sadly used my old cap to make a pressure cap for my MOTEX pressure bleeder. It seals well and will hold the 20 lb psi with no issue. I figured sourcing a cap would be no issue...I was wrong. The threads on my old cap are nicely pronounced too...the Moss cap is a very sad deal.
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
BOBBYR Girling brake booster Austin Healey 5
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
T Lucas girling brake pads Triumph 2
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
rr64 Wanted: Girling Brake Line Banjos Other British Cars 9
F girling master cylinder [brake] Austin Healey 3
A Wanted Girling Axle for TR2 Triumph Classifieds 5
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
HerronScott Lucas and Girling Triumph 3
H Rebuilding Girling 16P Triumph 5
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
P Girling brakes on a Chrysler? Other British Cars 8
Z Girling/Armstrong lever arm shocks Spridgets 2
