TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits?
karls59tr
Bronze
Apparently it's N/A. What grease should I use as a substitute for the dust seal area? I noticed when examining the caliper pistons upon removal it was the ridge in the piston caliper and around the caliper bore that were rust prone. I would like to avoid this on the rebuild.
K
karls59tr
Bronze
Did you coat the pistons and the spring and all rubber parts with it? Are you sure it is compatible with brake fluid? It's my understanding that the original Girling red grease is made form some sort of "vegetable compound" that dosn't affect the rubber parts.
DougME
I've been using the regular Napa Sil-Glide, 7651346, successfully for many years, I never knew the brake version of it existed until I looked it up today.
I've seen no degradation of the rubber whatsoever, even after many years on my numerous vehicles, guess I'll continue using what I have and then buy the brake type. And yes, I generously coated everything with it, rubber cups and boots and metal including the pistons. Besides coating all the surfaced I would wipe a gob all the way around the metal brake cylinders up onto the rubber boot making a fillet there so NO water was going to get in.
Only trouble was on my Girling Land Rover master cylinder. I must have put a bit too much silicone grease on the metal piston which slowed down it's return action after releasing the brake pedal. There is only a small spring inside the MC to return the piston to it's home position, my too generous application slowed down the return action causing a slight delay before I could pump the pedal again, time has eased this problem.
K
karls59tr
Bronze
Thanks for the information. I've since been contacted by a Triumph club member here who says he has had success with the silicone product as well so that seems to be a good replacement(y) for the red grease which has become hard to find and expensive with shipping.
PAUL161
I use Sil-Glide and have never had a problem, I also use Silicon brake fluid, no problem there either. PJ
Scott_Hower Girling Red Rubber Grease? MG 1
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
R TR2/3/3A Girling Rear Brakes Triumph 9
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
