Weber Carb trick
mightymidget
In a previous thread about the fuel inlet on my weber carb being on the hot side of carb someone posted a photo where the Weber was turn 180 from standard.
Well thanks for that photo. I am in the process of doing this.
I ordered a throttle cable for a 1500 from Moss (you can not beat there service)and it works perfect for the extra length needed to wrap around carb.
Other than needing to attach a clip to hold the throtle return spring it is a pretty simple trick to do. the only thing I need to complete modification is buying a new choke cable long enough to reach around to front of carburator.and vacuum line extention
Now my Fuel line is run along the inner fender, not even close to radiator or exhaust manifold as before.
Plus another big advantage is the carb mounting bolts are alot easier to get too.
M
mightymidget
https://yfrog.com/afmgjune2010weberturned18j
Posted this photo for future reference. the choke cable is a NAPA 60" universal.
One problem I have is that the lower blade linkage rubs the intake causing the throtle to hang slightly. I blip will settle it down.
Easy fix- remove the carb one more time and grind some if intake down so linkage doesn't rub. I tried to bend it but realize that wasn't a good thought.
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
msoylemez Weber Carb Rebuilds Spridgets 5
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
