Sprite Weber carb question and problem!
jgcable
Here are the symptoms: The car starts instantly and idles nice but as soon as it gets warm (around 180 degrees)the idle begins to change and become erratic with the car eventually stalling. The electric choke works perfectly and opens when the car is around 140 degrees. It smells like it is running rich. I am trying to tune this carb and so far I am not having much luck. I can't even figure out what model it is. I think it is a 32/36DFEV but I can't be sure. I have followed the Weber website tuning directions but I can't be sure I am even turning the correct screws. Can anybody point out what the screws are that I circled in black? These carbs are supposed to be simple to tune but I am having no luck so far. Here are some pics!
Hello Jg,
mthe upper screw you have circled is the jet retaining screw and holds the jey, ther is one similar on the oppisite side. the lowere screw is your mix adjustment. screw in to lean out out to richen. hard to see for sure but make sure the jet retainging screw are snug and follow the webber instructions. Good Luck keep us posted
Mark
J
jgcable
I downloaded the Carburetor Set Up and Lean Best Idle Adjustment instructions from Redline Weber Carburetor. Hopefully they will solve the problem. If not.. I will remove the carb and tear it down and rebuild it. The old gas tank had alot of rust in it that actually clogged my fuel filter so maybe some of it got into the carb. Does it matter where the fuel filter is located? It was located right outside my carb but I mounted it near the gas tank because it is easier to get to considering my tank is inboard.
George Zeck
I have SU's so I can't be of much help on that Q. BUT -- on the fuel filter, I placed mine next tot the carbs and bought the clean glass one so that I could get a "quick look" when ever needed (I didn't want to crawl under the car to see if fuel was getting where it was suppose to). Hope this helps.
J
jgcable
Ok, so I followed the Weber Redline base specs and the engine starts perfect and idles nicely. I now am experiencing a pretty severe hesitation. It stumbles (hesitates) really bad when I initially step on the gas. After I get past the stumble it revs up fine. Any suggestions?
Biff
jgcable,
Are you running with the vacuum advance on the distributor? If so plug the vacuum hole in the intake manifold and the line to the distributor and see if that helps. I tried using the vacuum advance without luck and am now only using the mechanical advance. I set my timing at 34 degrees total advance at 4000 rpm and let idle advance work itself out. This eliminated the stumble I had with my setup.
J
jgcable
[ QUOTE ]
jgcable,
[/ QUOTE ]
Yes, I am running the vacuum advance on my distributor but my line goes from the weber carb to the distributor. There is no line coming out of my manifold.
J
jgcable
I am still having engine problems. I think it might be the Weber 32/36 DFEV. It has a pretty strong burnt fuel smell coming from the tailpipe. To me, the engine seems to slowly drown in fuel. After it warms up the engine starts to load up and the idle becomes bad. It eventually starts to idle down and eventually stalls. It starts right back up and runs great but only for a few minutes and then the same thing happens. I just ordered a rebuild kit for the carb. Does anybody think there could be any other problem?
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
lbcspinners New article today from Hagerty Media: the Austin-Healey Sprite Austin Healey 0
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
B Bugeye Sprite Wiring Diagram Spridgets 4
