What size battery for my '67 Sprite?
Bayless
I am getting really close to time for a battery. I will be installing the gauges and switches this week. I have seen groups 22, 24 and 26 offered as correct and now I am confused. Also, I have checked my tachometer and think is is still set for positive earth. I don't want a radio or electronic ignition and if I need to charge my phone, I'll do it before I leave home, so I don't have any reason to convert.
twas_brillig
I just had a look at a battery supplier's page for various years and models, and they identified a swack of different Groups as being suitable. I suggest that you follow the approach we used decades ago when our Bugeye was our only car (summer and winter): measure the size of the hole, and buy the biggest battery that would fit in it. Make sure the posts were going to be the right place and that the height wasn't excessive. Maybe put a battery box in the hole first as well or something like an election campaign sign to provide a bit of a non-conducting, non-rusting layer.
I don't remember if the passenger side grab handle has a piece of wood behind the dash, but put one in there and attach a cigarette lighter/power take-off to the wood (so no worries about what to ground to) - we did this for our 3000. It's not visible, but can provide a GPS connection (or a phone connection, etc.)
Bayless
Bayless
Thanks. Sounds like good advice.
Boink
Bronze
I got a very nice one at Costco for my Bugeye... the only issue was to be sure to get the positive terminal (I still have "+" ground) on the correct side. Wish I could remember what it is... but I could go look.
twas_brillig
LHD car jas the positive ground on the driver's side. My recollection is that the post should be closer to the firewall. Doug
Bayless
Bayless
Thanks for the additional information. With all the hype, one would hope the Horley book would have much of that. It is a great book and has a lot of historical content but there is so much missing. Well next time I'll know all this stuff. Oh wait, a "next time" is pretty unlikely.
D Battery Tray Size Austin Healey 1
PatGalvin TR2/3/3A TR3 Battery Size Triumph 13
AH67 The size of battery for 62 BN7 Austin Healey 16
Johnny What size Battery for a AH BJ7 neg grd Austin Healey 16
rikiwho123 battery size Triumph 4
I Battery - does size make a difference? Spridgets 8
M_Pied_Lourd TR2/3/3A Battery CCA/CA and Group Size TR3A Triumph 7
S Size 34 Optima Battery w/positive ground Austin Healey 33
58Custom What battery size do I need? Spridgets 8
F Spitfire Battery Size for Spitfire 1500 and TR6 Triumph 3
78MGB 12 Volt Battery Size MG 12
A Battery Size Spridgets 9
H Correct Battery Size for 100-6? Austin Healey 4
kyreb1862 MGB MGB Battery Size MG 16
Monark192 Battery Size? MG 2
JeffR Battery Size for BJ8 Austin Healey 2
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
