TR2/3/3A TR3 Wheel Lug Nuts Size?
Bocaray
Just discovered my TR3A has different size lug nuts on one wheel. This is just the nuts, studs look the same. What is the correct lug nut size???
TomMull
I doubt you'll find them by size. I think the studs are 7/16 NF. "Standard" 7/16 lug nuts have a much smaller OD. You can uses the smaller nuts but they won't fit the wheels properly. Very embarrassing to see one of your own wheels pass you on the highway. I'd order them by part number from one of the usual suppliers.
Tom.
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
K TR2/3/3A Wheel Lug Nut Torque for a TR3? Triumph 2
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
W TR2/3/3A TR3 wheel studs Triumph 4
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
T TR2/3/3A TR3 wiper wheel boxes Triumph 5
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
Number_6 TR2/3/3A TR3 Wheel paint Triumph 8
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
O TR2/3/3A TR3 Wheel Bolt Pattern Triumph 1
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
K TR2/3/3A TR3 wheel specs? Triumph 3
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
K TR2/3/3A Installing wheel studs to hub TR3 Triumph 2
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
T TR2/3/3A tr3 steering wheel resto Triumph 5
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A wheel spacers for TR3 Triumph 13
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
A TR2/3/3A TR3 steering wheel support Triumph 10
T TR2/3/3A TR3 wheel bolt pattern Triumph 7
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
S TR2/3/3A narrow wheel tr3 Triumph 13
K TR2/3/3A Who used 1/2" wheel lugs on their TR3 hubs? Triumph 1
NutmegCT TR2/3/3A TR3-4 owners: wheel poll Triumph 21
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
fad64b TR2/3/3A TR3 steel wheel color Triumph 6
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
A TR2/3/3A TR3 Wire Wheel painting Triumph 2
martx-5 TR2/3/3A TR3 Wheel Info Needed Triumph 1
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
