TR2/3/3A TR3 Wheel paint
Number_6
I know this has been discussed but I can't find the thread. What color silver paint is best to paint the rims on a TR3A? I believe it was mentioned Eastwood has a close match but looking at their site I see a few different silver paints. This will be one of my small spring projects for this year repainting the white rims on my '3 to the correct silver.
af3683
Here is what I've been able to find:
Ford Silver - DAR-2593 (Argent Silver)
Ford Silver - PPG - DCC2593 polyurethane (Argent Silver)
Hammered Silver - Ditzler DAR 2593
Bill Piggott’s book: Aluminum/Silver Wheel Paint Dockers CD 31568
1974 /1976 Ford Granada Silver
Art
M_Pied_Lourd
Not for a 3 yet...but used this one on my TR6 wheels and was/am very happy.
https://www.eastwood.com/silver-argent-rally-wheel-paint-set.html
Cheers,
M. Pied Lourd
mrv8q
+1 with MPL
M_Pied_Lourd
Forgot to mention, I also used the Eastwood Diamond Coat Clear on them as well.
Cheers,
MPL
LarryK
The Argent Silver as stated above is correct or look up 1976 Ford Granada/Mercury Monarch Silver was used in the 70s and 80s as concours silver on wires and etc. for all English makes.
This14u
Agree with using PPG DAR-2593 silver. I used it on my Spitfire wheels and they look great. A pint was more than enough to completely paint five wheels.
Number_6
Number_6
Thanks for the replys, lot of good info. I'll post some pics of the wheels after I get them painted. Right now they are painted white which the guy I bought the car from assured me was the correct color for the '61 TR3A. At the time i didn't know any better, now of course, I know they should be silver.
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
W TR2/3/3A TR3 wheel studs Triumph 4
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
T TR2/3/3A TR3 wiper wheel boxes Triumph 5
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
K TR2/3/3A Wheel Lug Nut Torque for a TR3? Triumph 2
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
O TR2/3/3A TR3 Wheel Bolt Pattern Triumph 1
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
K TR2/3/3A TR3 wheel specs? Triumph 3
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
K TR2/3/3A Installing wheel studs to hub TR3 Triumph 2
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
T TR2/3/3A tr3 steering wheel resto Triumph 5
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A wheel spacers for TR3 Triumph 13
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
A TR2/3/3A TR3 steering wheel support Triumph 10
T TR2/3/3A TR3 wheel bolt pattern Triumph 7
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
S TR2/3/3A narrow wheel tr3 Triumph 13
K TR2/3/3A Who used 1/2" wheel lugs on their TR3 hubs? Triumph 1
NutmegCT TR2/3/3A TR3-4 owners: wheel poll Triumph 21
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
fad64b TR2/3/3A TR3 steel wheel color Triumph 6
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
A TR2/3/3A TR3 Wire Wheel painting Triumph 2
martx-5 TR2/3/3A TR3 Wheel Info Needed Triumph 1
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
