TR2/3/3A TR3 Rear wheel cylinder attachment clips
tmeinc1
Can someone post a picture or refer me to a good diagram of how the clips are supposed to be attached to the wheel cylinders on the TR3? I have had these off and on on my TR6 without a thought. Now I'm restoring a TR3A and the system is the same but there is a third clip called a distance piece that I never had on the TR6. I can barely get the two large clips into the goove on the cylinder. I can't imagine how a third clip can be inserted. Also, I got dust covers that came with the kit. One end goes over the hand brake lever, but I haven't a clue what holds the whole thing in place. Sure hope someone can help.
TR3driver
Great Pumpkin - R.I.P
Unfortunately, AFAIK all the diagrams are wrong. But if you follow the written procedure in the back of the workshop manual, it goes right together.
Poke the cylinder through the backplate, without the handbrake lever. Slide the distance piece (the smallest one) into place with the opening away from the handbrake lever and the tabs away from the backplate. Then slide the spring plate (the big one with the tabs sticking out) in between the distance piece and the backplate, also with the opening away from the lever and tabs out. Now install the lever. You may need to tap it into place, but I can usually just push on the cylinder and slide the pegs under the end.
Now tap the retaining plate in from the other side, between the distance piece and the spring plate, until the tabs on the spring plate engage with the slots in the retaining plate.
In theory, I think the boot is supposed to snap over the retaining plate, but mine never do. Doesn't seem to hurt anything to just leave it hanging there.
T
tmeinc1
Many thanks to you and TR3driver for yopur replies. Both were very helpful. The TR3 and TR6 system is excactly the same. I just never had the small clip on my TR6. Looks like I have a fun job ahead.
Not sure if they are the same but this site explains the TR6 ones very well. https://www.buckeyetriumphs.org/technical/Brakes/Rear/Rear.htm
Randall, am I correct is saying that the early Lockheed setup had no clips holding the wheel cylinders in place?
Cheers, Mike
TR4nut
This topic comes up occasionally, and unfortunately it is one of the rare instances where the Buckeye information is not quite right. The little spring plate with the turned up edges is not the last piece to go in - it can be done that way as others (including me) have done, but it is much harder that way. Here is a link to the same topic, the message is - the middle piece gets put in last:
https://www.britishcarforum.com/bcf...p-Installation&highlight=wheel+cylinder+clips
TR3driver
That's the way I remember it, but it's been a long time. The twin front cylinders are actually bolted to the back plate, but the single rear cylinders just float in the hole. There is a flange that keeps them in the hole while centered (and the shoes hold them centered), but no clips.
T
tmeinc1
I just want to let everyone know that I successfully installed all the parts. I used a combination of the procedures from TR3driver and mgedit. I put the dust boot in place right after installing the spring plate. Then I slid the locking plate in place and the dust boot nested nicely beneath the locking plate and around the spring plate. What really baffled me was that the distance piece looks like it should be the last piece installed when, in fact, it's the first piece. Many thanks to all for your help. Now I have to get the missing pieces for my TR6 and do that job correctly.
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
