TR2/3/3A TR3 Exhaust header's proximity to rear of generator?
karls59tr
Bronze
Anyone else running exhaust headers and find that the front pipe is too close to the generator causing the generator to get so hot that it melts solder connections inside? Anyone have any recommendations for a" heat shield" to wedge between the two?
TR3driver
Great Pumpkin - R.I.P
In my experience, thrown solder indicates a misadjusted (or incorrect) control box rather than headers too close. I ran headers for several years with no generator problems, once I learned to set the box by the book.
But it should be easy enough to fab something from thin sheet metal. Cut and bend a couple of tabs to clamp to the header tube with a hose clamp.
Another alternative would be an alternator conversion. They are usually shorter and hence leave more room.
Geo Hahn
My non-TR has a simple sheet metal heat shield behind the alternator. The early version was more of a shroud but then they went with something much simpler:
Of course it may well be that an alternator (esp the diodes) is more vulnerable to high heat. I've never had an issue with the TR Dynamo so long as I kept the rear bearing oiled.
TR3driver
Geo's photo reminds me of another point : the insulation on the wires will melt and run at a much lower temperature than the solder melts.
Interesting photo, Geo. Early 70s Jag, with the externally regulated Lucas 11AC alternator ?
Alan_Myers TR2/3/3A Comments - TR3/4 Falcon S/S header & sport exhaust Triumph 1
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
C TR2/3/3A TR3 Exhaust Recommendations Triumph 3
tr3guy TR2/3/3A New TR3 Exhaust System Triumph 6
S TR4/4A exhaust manifold gasket also later tr3 Triumph 2
TRclassic3 TR2/3/3A TR3 Monza Exhaust installation Triumph 2
T TR2/3/3A tr3 exhaust opinions needed Triumph 12
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
J TR2/3/3A TR3 exhaust manifold stud thread size? Triumph 3
M TR2/3/3A TR3 Falcon exhaust fitting issues Triumph 4
mgedit TR2/3/3A 56 TR3 Intake and Exhaust Manifolds Triumph 8
T TR2/3/3A TR3 SS exhaust Triumph 8
M TR4/4A TR3 TR4 exhaust hanger question Triumph 4
PatGalvin TR2/3/3A TR3 Exhaust System - how does it fit Triumph 3
Tinkerman TR2/3/3A TR3 Exhaust Manifold Clamp Question. Triumph 1
Tinkerman TR2/3/3A Exhaust Manifold TR3 Triumph 1
PeterK TR2/3/3A TR3 exhaust guide conversion Q. Triumph 3
S TR2/3/3A tr3 exhaust manifold Triumph 0
S TR2/3/3A tr3 exhaust manifold gasket Triumph 5
MGTF1250Dave TR2/3/3A TR3 Intake Exhaust Manifold Studs Triumph 9
S TR2/3/3A tr3 exhaust manifold Triumph 8
MGTF1250Dave TR2/3/3A TR3 Exhaust System Resonator Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
