TR2/3/3A put a differential back into a tr3.
sp53
It has been a while since I put a differential back into a tr3. Is the best way to put the leaf springs back on at both ends of the frame and then push the leaf springs up with a floor jack onto the differential and then put the U bolts in place? Or should I leave off one end of the leaf springs and bolt the U bolts onto the differential and then re-hook the other end of the leaf spring some how--- probably by jacking it up with a floor jack? Any input is much helpful.
Steve
CJD
I don't know if there is a best way, depending on whether your body is installed, loose, or removed. This is how I went about it:
mastaphixa
Bronze
I installed mine by leaving one brake backing plate off and feeding it thru on top of the the springs. I may have had the back end of one of the springs disconnected (the side I fed it from). I actually don't remember. I do remember it wasn't as bad a job as I thought it would be.
J before I put this in my differential Triumph 8
T Got the engine put together Spridgets 4
S TR6 After I put in my new oil pump.... Triumph 3
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
M TR2/3/3A Where have you guys put your stereos and speakers? Triumph 3
M TR2/3/3A Phone charger & Radio can I put these in my car??? Triumph 7
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
R TR4/4A About to put in an OD Transmission. What else should I do while in the air Triumph 7
T TR2/3/3A Should I put flat washers on sump bolts? Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
glemon General TR Time to Put Your Tops Up? Triumph 12
jlaird Before I put in classifieds Spridgets 36
Bob McElwee Rode Hard and Put Away Lovingly Austin Healey 6
J How to put a stop on the end of a choke cable? Restoration & Tools 2
M Who put the stick in my heater hose? Spridgets 6
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
drooartz Help me put together a plan for my Bugeye Spridgets 46
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
R 100-4 PUT-BACK-TOGETHER ?'s Austin Healey 2
RickB Just put headrest speakers in - wow! Spridgets 8
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
DrEntropy Can't put it off any longer. MG 10
M Body ready to be put on Chassis, 1 question first Triumph 9
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T Where to put the OD relay? Triumph 13
bugedd Before I put it on ebay.... Spridgets 0
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
Basil Where to put that bumper sticker Spotted 1
middie Before I put engine back Spridgets 22
Jims71TR Put a new fuse box in now I have troubles Triumph 15
regularman Has anyone here put a bugeye front end on a square Spridgets 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
doughairfield Where to put the ground. Triumph 6
B Before I put the heater in my 57... Triumph 10
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
bigjones Spare coil - put it under the hood? Spridgets 8
Marvin Gruber Put off too long Jaguar 4
T OT - what do you think, put a Rover V8 in it? Triumph 29
T Did they put TR frames under these? Triumph 8
jackq Something to put in front of your MG MG 0
Tinkerman Need to put a new hole in my dash! Triumph 20
JohnnyMead What to Put Under Carpeting? Triumph 11
I TR6 TR6 put put sounds, part 2 Triumph 74
T What do you think - put a team together for this? Triumph 2
livinginthepast Stupid Q dejour - horn push/badge won't stay put! Spridgets 14
T Largest tire size I can put on my 89 xj40 Jaguar 1
