TR2/3/3A Modern Temporary Donut Spare for a TR3
jfarris
Is anyone using a modern "donut type" spare on a wire or steel wheel in an early TR3?
How is the fit? 48 or 60 wire?
Thanks!
Thor Modern temporary spare tire that might fit 1500? Spridgets 0
DrEntropy Some crabbing about 'modern' cars Other Cars 11
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
M TR5/TR250 Compatible Modern Tire Size Triumph 5
glemon Modern Cars [and some perspective] Other Cars 9
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
M Fitting a modern radio Austin Healey 9
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
billspohn Modern Classics-to-be? Other Cars 33
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
M Modern Parts & Service Spridgets 21
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
Healey Nut Modern accoutrements Austin Healey 23
rjc157 Modern Radio Austin Healey 12
glemon Modern Morgan? Other Cars 3
C BMW or other Modern engine-What would you use? Austin Healey 33
Sarastro T-Series Modern Electrics for a TD MG 9
M_Pied_Lourd TR2/3/3A Modern Paint Reference Numbers Spa White Triumph 7
5 Modern [Burlen] SU fuel pumps Austin Healey 7
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
rjc157 modern radio Austin Healey 5
Bradhowesable TR2/3/3A Modern audio in a Tr3A? Triumph 13
aeronca65t "Modern" classic British Motorbikes 4
K Modern Epoxy instead of Welding? Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
K TR2/3/3A Modern Fuse Box on a Tr3? Triumph 7
drooartz Removing modern radio MG 5
cbrvfr Running modern accessories with positive ground? Austin Healey 4
newmexTR3 TR2/3/3A TR3 & Modern Art converge Triumph 5
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
dougie "Modern" Healey Commercial Austin Healey 3
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
bighealeysource Modern color code for MG red MG 3
F Old Cars, Modern Radios Triumph 15
jhorton3 Modern Radios Spridgets 10
prb51 Modern Starters on Tr's Triumph 10
S Modern day Spridget? Spridgets 8
MTribe modern paint code for Signal Red? Triumph 5
A Old English white modern equivilent? Austin Healey 12
John_Mc Modern marvels Triumph 2
R6MGS *modern* cars.....rant Other Cars 21
7 How often do you change... [on a modern car] Restoration & Tools 8
MadRiver Modern or rebuilt alternator? Triumph 14
R Modern Jack for a BJ7 Austin Healey 9
