Modern Radio
rjc157
I'm trying to hook up a modern radio in the car its negative ground already and I need to attach two power leads one to a constant 12 volts and one to the switch ,can I do this from the fuse box ,any suggestions I was thinking of going to the starter solenoid and one to the right side of the fuse box
dwalpole
Member
When I wired a modern radio into my 6, I pulled from the purple line which powered the glove box light (always hot), for the constant requirement. I pulled off the green switched or pink./white for the switched line. I would avoid the starter solenoid to avoid the voltage surges when that activates. Both were behind the dash already.
GregW
Keoke
They say the first thing to go is your memory how to hook up your modern radio. :jester::devilgrin::jester::devilgrin: Just kidding, Ray.
You have received some BAD information I suggest you tune to another station..:angel2:
Keoke
rjc157:
You may want to hook all the power inputs for the radio to a common point that is switched off when your car is not in use. This is because the memory can drain the Battery if the car is not frequently used. -Just a thought.
rjc157
rjc157
I did that the only problem with this radio is that every time you turn it on all the presets are erased and you have to start all over again
RAC68
Hi Ralph,
Yes. You can attach the switched current to the green side of the smaller fuse and the constant current to the brown radio line, already included in the harness for the radio. The constant power is usually used to provide radio security and you will still need to reenter your security code and presets after you switch off the master power switch. If it hasn’t already, I would install an in-line fuse to protect that line.
Depending upon the type of radio you are installing, this article may be of some help (https://drive.google.com/file/d/0Bx...MWMxLWI3MzItZmVlNjBiNjlhMWEw/edit?usp=sharing).
All the best,
Ray (64BJ8P1)
Keoke
Well I know that but which is the most inconvenient, resetting the presets or being faced with a dead battery.????
Alliteratively you could hook the radio up in the standard manner and keep a battery minder-Pulse Charger- on the car when it is not being used. then the presets will remain set and the battery will not discharge.
healeyblue
I would go with option two. Keep it on a minder if not driven often, better for the battery anyways.
RAC68
It will only take a very small amount of power to keep the radio's memory active and security in place. I have had this for quite a while with no concernable loss in battery power over a 2 week period when the car was garaged with master switch on. However, in practice, I usually turn off the main switch when not expecting to use the car for more then a day and use the radio scan function or tape/disk players rather than depend upon the presets.
Ray (64BJ8P1)
dwalpole
Member
A slightly off the wall idea would be to wire the memory line to a separate battery. 8 AA in series = 12 V or possibly would work with a single 9V depending on the requirements for the radio. That would enable you to disconnect the main battery without losing your radio presets.
M Fitting a modern radio Austin Healey 9
rjc157 modern radio Austin Healey 5
drooartz Removing modern radio MG 5
B Modern radio for BJ8s' Austin Healey 0
DrEntropy Some crabbing about 'modern' cars Other Cars 11
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
M TR5/TR250 Compatible Modern Tire Size Triumph 5
glemon Modern Cars [and some perspective] Other Cars 9
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
billspohn Modern Classics-to-be? Other Cars 33
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
M Modern Parts & Service Spridgets 21
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
Healey Nut Modern accoutrements Austin Healey 23
glemon Modern Morgan? Other Cars 3
C BMW or other Modern engine-What would you use? Austin Healey 33
Sarastro T-Series Modern Electrics for a TD MG 9
M_Pied_Lourd TR2/3/3A Modern Paint Reference Numbers Spa White Triumph 7
5 Modern [Burlen] SU fuel pumps Austin Healey 7
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
Bradhowesable TR2/3/3A Modern audio in a Tr3A? Triumph 13
aeronca65t "Modern" classic British Motorbikes 4
K Modern Epoxy instead of Welding? Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
K TR2/3/3A Modern Fuse Box on a Tr3? Triumph 7
cbrvfr Running modern accessories with positive ground? Austin Healey 4
newmexTR3 TR2/3/3A TR3 & Modern Art converge Triumph 5
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
dougie "Modern" Healey Commercial Austin Healey 3
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
bighealeysource Modern color code for MG red MG 3
F Old Cars, Modern Radios Triumph 15
jhorton3 Modern Radios Spridgets 10
prb51 Modern Starters on Tr's Triumph 10
S Modern day Spridget? Spridgets 8
MTribe modern paint code for Signal Red? Triumph 5
A Old English white modern equivilent? Austin Healey 12
John_Mc Modern marvels Triumph 2
R6MGS *modern* cars.....rant Other Cars 21
7 How often do you change... [on a modern car] Restoration & Tools 8
MadRiver Modern or rebuilt alternator? Triumph 14
Thor Modern temporary spare tire that might fit 1500? Spridgets 0
