TR2/3/3A spare tire compartment holes for modern license
sp53
Anyone deal with how the spare tire compartment holes for modern license plates do not match the original ones on the spare tire cover from England. Anyways I am looking for a way to use the original holes on the tire compartment cover and not drill new holes in the cover or licenses plate. Perhaps some kind of 2 for one deal from a vender is out there?
CJD
Mine came with an adapter that I cleaned and re-used. I have not seen any modern equivalents.
S
sp53
How cool John and I do not have one, I am envious. I see some knockoffs on line, but maybe I will make one. Always looking for something makes me young and fulfills the primal motive to hunt. i think the cars i had the drilled the cover
steve
Frank Canale
I had not even thought about the license plate being mounted. I guess that makes two of us with another project to work on in our spare time . Very cool adapter that will make for a fun project. Thank you for the picture John. Frank
CJD
If you guys decide to make the bracket, it uses spacers on the studs to give enough room for the screws and nuts holding the plate...long enough to hold the bracket and plate away from the painted tire cover.
Frank Canale
I have already decided to make the bracket, but I don't know when I will start it. When I do I will check back for some dimensions if I get stuck making it. Frank
mgedit
Interesting. My 56 spent its early life in California. The holes in the cover matched the holes in my Ontario plate, and presumably the black CA plate that came with the car. Just as well, because I never thought of the holes when restoring and painting! Cheers, Mike
S
sp53
Somebody probably drill and filled your holes because the European plates are different. Or maybe they were not drilled until they hit America. I have a few old covers and will look better at them.
steve
Frank Canale
I got a chance to check my spare tire cover last night and my license plate mounting holes match modern plate so no need for adapter plate. Frank
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
G TR2/3/3A TR3 Spare Tire Compartment, post-60,000 Triumph 5
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
F TR2/3/3A Spare tire cover Triumph 8
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
S TR2/3/3A tr3 spare tire fit Triumph 16
O TR2/3/3A Spare tire Triumph 4
F TR2/3/3A Spare Tire Size Triumph 11
D Vredstein 185X70 Spare Tire Fitment Austin Healey 5
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
Chuck9482912 Mini Spare Tire Austin Healey 9
S TR2/3/3A body work on the spare tire panel Triumph 7
V spare tire Spridgets 5
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
S TR2/3/3A trunk/spare tire Triumph 9
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
maxwedge5281 wanted: spare tire holddown and body attachments Austin Healey 9
I TR6 spare tire cover Triumph 5
I TR6 69 TR6 spare tire lid Triumph 4
Superwrench Spare tire rod Austin Healey 2
F Proper location of chrome loop for spare tire strap? Austin Healey 2
Kleykamp Hole pattern on spare tire lock covers??? Triumph 5
mgedit TR2/3/3A Spare Tire TR3 Triumph 11
B MGB 78 MGB Spare Tire trunk lockdown thingie MG 13
H TR4/4A Spare tire bracket 4A Triumph 4
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
mgbmedic TR2/3/3A TR3A Weatherstripping / Trunk - Spare Tire Cover Triumph 11
M TR2/3/3A TR-3A - spare tire Triumph 4
A TR2/3/3A TR-3A Spare tire lid rubber Triumph 1
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
tmc Tire size for the spare Triumph 10
HEALEYJAG spare tire Healey 100 Austin Healey 7
K TR2/3/3A Up-date on TR3 spare tire Triumph 6
bcbennett Spare Tire Cover Triumph 1
bcbennett TR6 TR6 Spare Tire Triumph 27
luke44 TR2/3/3A TR3 Spare Tire Cover - Lock Triumph 5
tahoe healey Spare tire on boot Austin Healey 16
R TR6 TR6 Spare Tire Cover Needed Triumph 9
CinneaghTR TR4/4A Spare Tire Won't Fit in TR4A Trunk Triumph 8
bigbadbluetr6 TR6 TR6 Spare Tire Triumph 1
1 BE spare tire [tyre] is slipping Spridgets 17
T Spare tire question Triumph 21
rlandrum TR2/3/3A TR3A Spare Tire Well Bondo-fest Triumph 5
