Setup for single Weber carb
jorg
Hallo,
I am new here in this Forum and have a question about the carb setup for a 1977 1500 Midget. (In order to reach the Spitfire owners I posted at the Triumph-Forum too.)
Does anybody know what the basic setup for a single Weber DCOE 45 for a standard 1500 engine is? The car should mostly run under normal conditions with rpm between 1500-5000 with intention on maximum fuel economy and less power output above 6000 rpm.
The following basic setups for a single Weber DCOE 45 I found on the internet:
Choke 33
Aux. Venturi 4.5
Main Jet 190
Emulsion Tube F9
Air Jet 175
Pump 40
Idler Jet 45F9
Choke 34
Aux. Venturi 3.5
Main Jet 150
Emulsion Tube F2
Air Jet 175
Pump 50
Idler Jet 55F8
Accel. pump (jet) 50
Ex.Valve 50
Choke 34
Aux. Venturi 4.5
Main Jet 145
Emulsion Tube F16
Air Jet 155
Pump 45
Idler Jet 55F8
Ex.Valve 40
Thanks
Jörg
Germany
DesertSprite
Wilkommen Jorg,
I can't help you with the Weber carb, but someone here will chime in with the information you seek.
Just want to welcome you to the sickness.
Joel
jollyroger
This a kinda black art. There is a book. Weber Carburators. Read it carefully. Most important (here is a hint)to under stand that the idle jet affects the fuel mix across the rev range. After reading the book(focus on DCOE section) Follow the graphs in the front of the book based on cylinders, engine size and rpm. Do the math and you will be close...very close. No guess work. If you do this you will know for sure what the setting should be. The last one you listed looks pretty good, but you would do better to do the leg work. You will be glad you did and you won't be relying on others guess work. No engine is the same as another.
piman
Hello Jorg,
unless you have a Weber fitted already, you will not improve on the original carburettors for driveability and economy. The Weber DCOE is primarily a performance carburettor.
Alec
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
A For Sale Supercharger setup complete for Rover V8 3.9/4.0/4.2 Other British Classifieds 3
R TR6 TR6 Trunnion Setup Triumph 5
Sarastro TR4/4A Differential setup question Triumph 12
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
R TR2/3/3A Lockheed diff setup Triumph 6
apbos Interesting dual cylinder Bugeye setup Spridgets 6
D My Sand blasting setup Restoration & Tools 5
bugedd Mini Metro Turbo setup Spridgets 12
steveg Remote clutch bleeder setup Austin Healey 7
C TR2/3/3A TR2 Rear axle setup Triumph 1
DanLewis Disc brake setup on eBay for $79+shipping [NFI] Spridgets 2
maxwedge5281 rearend setup Austin Healey 7
PatGalvin TR5/TR250 Carb setup on TR250 Triumph 11
K TR2/3/3A TR3A Coolant recovery or overflow setup? Triumph 2
K TR2/3/3A Judson Supercharger Plumbing Setup for TR3??? Triumph 4
B Triple carb setup too rich? How to adjust? Austin Healey 3
Morris Pics of my COPs setup Spridgets 13
K TR2/3/3A Rad Coolant Return Setup for TR3A? Triumph 10
M BJ7 Rear Disc Brake Setup Austin Healey 7
B What is best electronic ignition setup MG 19
aeronca65t Corner weight setup Racing 3
D ID this front bumper setup? Spridgets 5
andybj8 Rolling Road Setup Austin Healey 3
K Adjustable steering wheel setup Triumph 2
rlwhitetr3b TR2/3/3A What is the carb setup on this TR3A? Triumph 8
cdsmith disk brake setup question... Spridgets 3
B Spridget Triple Master Setup Racing 5
TR4nut Pictures for picnic basket/luggage setup on TR? Triumph 23
G Modifying the triple intake choke/throttle setup Triumph 18
George Zeck Up & running with the new WEBER setup .... Spridgets 8
George Zeck Weber setup ..... Spridgets 3
B Shimming rocker setup Triumph 11
angelfj1 Powder Coat Setup Triumph 8
G HD8s Manifold Setup Jaguar 2
C MGB Weber DGV setup on 74 MGB MG 13
tony barnhill Rear Brake Setup MG 19
bmurphy7369 Wiring help needed badly... 1975 XJ6 Crane setup.. Jaguar 8
vping What in the world is this setup? MG 15
Bruce_B Cutting the car for a dual MC setup hints/tricks? Spridgets 23
T TR4/4A TR4 Timing Cover Setup Triumph 3
G Heat deflector for trips setup..... Triumph 1
Shealey anyone have a disc brake setup they want to part? Spridgets 49
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
G Rear hub/driveshaft setup Triumph 7
ChrisS Race Engine Setup Advice Spridgets 15
Kurtis HS-2 Carburetor Setup Question Spridgets 5
P GT6 vacuum setup on 1970 gt6+ Triumph 0
S K&N air filter setup questions. Triumph 5
PeterK TR6 Installing a TR6 M/C, servo setup in a TR4A Triumph 5
