TR4/4A Differential setup question
Sarastro
I've encountered a problem setting up my solid-axle TR4A's differential. I think I know what's going on, but I thought it best to pass it by you guys, in the hope that you might have more insight.
I clearly got the setup wrong first time I did it. This week I pulled the axle and checked the mesh with gear-marking compound, and it clearly wasn't right. The marks indicated that I should move the ring gear out of mesh, but the backlash was already at the spec maximum (0.006 inches). Anyway, by time I moved the ring gear enough to get a reasonable pattern, the backlash was 0.020 inches. That strikes me as way too much. I'm using a used ring and pinion set, so I'm prepared to go outside the specs a little, if necessary, but not that much.
My guess is that the gears are just worn. Do any of you agree, or have other ideas?
Madflyer
In a IDEAL WORLD with new gears you would have full face contact but 80 % is a good fit. and seating would be in the middle of ring face. As for lash .004 to .006 would also be ideal so placing pinion gear shim in the right order will get you into spec. I would not go under .004 and .010 max. Now depending on oil weight 90 to 140 ( this is a factor for the type of driving and weather ) Any time ring and pinion gears are moved some seating will happen IE. noise at HY speed, Look for any surface pits or color change on gears. Just changing bearings can cause a thing to change also.
bobhustead
If using a used ring and pinion, the set-up should be exactly like that in which the gears previously operated. Even if it is wrong.
Bob
Sarastro
Sarastro
Thanks for the responses. I could have been clearer.
This is a used gear set, which I bought to replace the original one. The original was actually rusted, so it was trash, and the bearings also were shot. I bought the used gear set, new bearings, the whole shebang.
I realized (or, at least, realize now) that it probably wouldn't be perfect, that I probably would have to settle for more backlash, and I expected some noise. But what I got was way too much of both. So, the basic question, I guess, is this: does this mean that the gears are too worn to use, or am I missing something?
bobhustead
Are the wear marks from the prior use at all visible on the gears? If you have the correct pinion depth and you can't get the lash/pinion to ring gap in spec, the gears will not be satisfactory.
Bob
Sarastro
Sarastro
Yes, I can see some wear marks, but they are fairly light, I think. In the past, I have seen ring gears and pinions with obvious wear, striations and such, but there is nothing like that.
bobhustead
Doesn't look too good, but hard to assess from a picture. Bottom line is you have evidence that the gears are not right.
Bob
titanic
To me, it looks like the contact is near the outside of the ring gear and the pinion should be moved deeper into mesh by putting shims under the pinion head. Then the backlash should be adjusted by moving the ring gear.
Berry
bobhustead
Berry
Problem is that the gear has obviously been run a long time in one position and you can't, without engendering a racket and likely premature (and sometimes very quick) gear failure, put the old gears in a new position.
Bob
Sarastro
Sarastro
It's starting to sound more and more like I should just bite the proverbial bullet and get new gears. They aren't cheap, but fortunately they are available.
The upside of this experience is that it has really been an education. I don't mean that cynically; I think I've learned quite a lot, and that has real value.
titanic
Steve-Looks like the only options are new gears, take a chance on used gears, or take a chance and install your present gears after resetting to the correct contact.
Berry
CJD
Can we get a pic of the pattern? The pic above looks like it was after you wiped the grease off...or you need a bit more grease across the face to better highlight the contact patch. I doubt you need a new gear...
Sarastro
Sarastro
Sure. Here are the last two iterations. The first two pictures (1344.jpg and 1345.jpg) are with 14 mils of backlash. The pattern is still pretty well toward the toe. My references say that this is still too far into mesh, and that I had to move the ring gear farther from the pinion. I tried that, and got the second set of pictures. the pattern is a little more centered but still not there, the backlash is now 20 mils (!). It also seems too close to the edge of the tooth.
So, that's the problem. My info says that the ring gear should be moved even further out of mesh, but that's clearly not possible. That's why I concluded that the gears are probably worn.
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
