TR6 TR6 Differential Rebuild question
Jerryny
Morning all,
I have a 73 TR6. The differential is making a small clunking sound when its rotating The car is up on stands and both axles have been disconnected. I am wondering if anyone knows of a quality shop that rebuilds triumph differentials. I'm near Albany NY, but am willing to travel to NJ, Conn, Mass.
Thank You in advance.
Jerry
J
Jerryny
Thanks. There is also a place called britishmotorsltd in Ct that does engine rebuilding, transmissions and a whole host of other things.
Madflyer
Is the clunking when rotating back and forth if so it is just the gears to lose and can add add shims to set gear lash to 0.004 0.006 check in three places on gear. If the flanges slide right off then they are broken at the key way and seals are most likely bad also. There is no drain plug and you can do that at the same time on the end cover. Madflyer
Rod-H
Bronze
Plus One on Quantum Mechanics, they did a great job on my TR4 rear end.
Rod
poolboy
It clunks all while it's rotating or just when the rotating first begins ?
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
SkinnedKnuckles TR6 TR6 Differential Rebuild Triumph 4
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
L Wanted Tr6 differential Triumph Classifieds 9
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
T TR6 TR6 Differential Ratios Triumph 8
glemon TR6 tr6 differential seal Triumph 10
W TR6 TR6 Differential Question. Triumph 6
MTribe TR6 TR6 differential leak fix - what to do? Triumph 11
mgedit TR6 TR6 Differential Mounts Triumph 6
K TR6 tr6 differential - need feedback! Triumph 16
J TR6 Last TR6 differential question Triumph 16
R TR6 TR6 differential internal upgrade Triumph 0
H TR6 Tr6 differential backlash Triumph 2
Aeroken TR6 TR6 Differential Inner Shaft Seals Triumph 8
T TR6 What year TR6 did NOT have a differential oil drai Triumph 11
C TR6 TR6 Differential Oil Seal ? Triumph 0
tr6web TR6 DIfferential and support damage TR6 Triumph 20
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
