laneriddle
If the diff(I think) is clunking some and you know the mounts are good and everything from the wheels in has been replaced ,the only thing left is the diff right?
So remove and rebuild?
I can remove the diff no problem but can’t rebuild it . If it’s not to bad could it be just a few internal parts ? What little research I’ve done,it sounds expensive.
