Mini Metro Turbo setup
bugedd
Let me preface this with that I am a bit odd. I've had a couple turbo'ed cars and have an affinity to the sound of the turbo wheel spinning up and the power kicking in. My last driver was a 92 Mitsubishi Galant VR4 with a very healthy 2.0L turbo'ed motor with AWD, and it was on par with the Evo's and STI's out there. Prior to that, an 89 Chrysler Conquest was my driver. Again, a turbo'ed car, 2.6L with rear drive and a limited slip. This established my sickness.
I've been poking around at the parts available to convert Ms. Scarlet to a turbo, and it seems like an intake/carb and exhaust/turbo setup from the Metro turbo is essentially a bolt on. Add in the boost compensating fuel pressure regulator, and it would appear that's all there is to the equation.
Has anyone had experience with this conversion, and am I leaving anything out? yes, I know I'll have to keep the boost down on a stock compression motor.
nomad
Been done by a friend in the club I belong to. Flatwater Austin Healey club out of Lincoln and Omaha Neb. His main problem is too much heat and carb vapor lock. Don't know if he really ever got it sorted but I would imagine if you poke around others have done it as well. If you have no luck I don't imagine he would mind talking to you and I can give out his e-mail addy if you PM me after you do some searching.
Kurt.
AN5Sprite
Kurt.
Sounds like a good excuse for fuel-injection too...
I don't know, but I feel like if it was a simple swap, we'd see it often. Isn't there a difference in the lower end of an "A" vs "A+" series block?
Maybe it doesn't fit under a Bugeye bonnet... There has to be a glaring flaw because you just don't see it on Bugeyes... (I'm just thinking out loud)
dklawson
I have no first-hand experience with the Metro Turbo. I also don't know how much room you have under the BugEye bonnet for the turbo and carb components. However, the turbo is not so much "low" on the engine but more-or-less centered on the back side of the engine block as you can see in the picture linked below.
https://farm3.static.flickr.com/2657/4115992436_dec2d1ef53_b.jpg
I would be hesitant about fitting the turbo to a small bore A-series. I suspect all the parts were sized for the 1275. I also have seen several discussions about the need to keep the compression relatively low to prevent head gasket failures. Basil does not like it when we post links to other boards. However, for the A-series turbo stuff I encourage you to visit places like "The Mini Forum" (www.theminiforum.co.uk). You will find a number of turbo enthusiasts and threads regarding the turbo on that board. I suggest using Google to find those threads. (i.e. Google search using a phrase like "theminiforum.co.uk turbo"). One section of the board dedicated to turbos is linked below.
https://www.theminiforum.co.uk/forums/forum/24-forced-induction/
It is more common in the UK (for obvious reasons), but still not widely done. To fit under the bonnet in requires modifications, although it seems many of them just install a "blister" in the bonnet for clearance.
bugedd
bugedd
Hood clearance would be a deal breaker. Thanks for some of the tips, I'll poke around and see what else I can find out.
Billm
Doesn't Glen Burns (in Davis California) have a turbo on his Bugeye? I don't remember that he had a bump in the hood
I know that he had Megasquirt but I think that he also had turbo
Davis is not too far from Chico
BillM
drooartz
Given how rare that Metro setup here in the US is I'm not surprised folks haven't tried it much. With Moss's supercharger setup available (even if expensive) as a bolt on it's hard to compete. Still, more options are always interesting.
The setup I'm starting to get interested in is fuel injection from these guys (Patton Machine). Obviously not the same as forced induction, but interesting all the same.
Glen's system was a homebrew setup using an old rayjet turbo.
Fuel injection on the stock a-series head is real tricky to optimize due to the siamese ports. The mini guys have all sorts of variations to solve the issue. None of them are simple. The simplest way to me, would be to buy a cross flow head and then do port injection with motorcycle throttle bodies.
bugedd
bugedd
How do I get in touch with Glen? Davis is a pretty short drive.
HealeyRick
Glen's last name is spelled "Byrns". He used to be a regular on the mail list, but haven't heard from him in awhile. He was running a Rajay and not a Metro turbo. If you want more info on his set-up, you can go to the mail list Spridget archives and search on "turbo" He had plenty of posts. Here's the archives link: https://www.team.net/mharc/archives/html/spridgets/
bugedd
bugedd
Thanks for the info. Turns out I know the car, he was right next to me at the car show I went to in spring.
nomad
Check out Aisin superchargers on flea bay. I have one that is going to boost a A14 Datsun. Will require a bit of fab work and I already have enough compression that I can't run a lot of boost but the setup will be LOTS cheaper than Moss.
Kurt.
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
TomMull For Sale 10 inch Mini Rims (2) Other British Classifieds 1
Basil Mini Pick Up Spotted 8
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
pbraun Alex Moulton's special Mini Moke for sale Other British Cars 0
C Autocrossing a classic Mini problems Other British Cars 2
Sherlock Mini Cooper patina Spotted 0
Basil The Queen in a Mini! Spotted 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
GB1 Classic Mini Mayfair Auto Other British Cars 1
Baz 2012 Mini CEL - Now it begins........ British Motor Corp 0
J 2006 Mini Cooper S British Motor Corp 6
N Classic Mini Engine Identification British Motor Corp 6
P Classic Mini advise British Motor Corp 1
D Possible Mini Gauges? British Motor Corp 6
S For Sale Austin and Morris MINI Factory Workshop Manual on CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
tr6nitjulius Mini @CCBCC All British Meet 7/14/19 British Motor Corp 0
JPSmit Green Mini - with halo headlights Spotted 0
Alfred E. Neuman Austin Mini Breadvan Spotted 0
AngliaGT Real Mini Spotted 0
S TR2/3/3A Tr3/Mini Girl Triumph 0
T Will Mini Spin on Adaptor work on Bug Eye? Spridgets 10
Bob Claffie Ultimate Mini British Motor Corp 3
coldplugs Jensen Interceptor & a Mini Spotted 8
pbraun Mini Meet East 2017 British Motor Corp 4
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
Basil Mini? Spotted 5
hutten Wheel sizes for Rover Mini Mark VII British Motor Corp 1
JPSmit Mini + iphone question Other Cars 3
Chuck9482912 Mini Spare Tire Austin Healey 9
B Mini Windscreen Wiper Parking British Motor Corp 3
3798j AACA Museum's Micro & Mini Exhibit Other Cars 1
J Motorcycle oil for Mini, based on shared oil British Motor Corp 4
DrEntropy Mini brake conundrum British Motor Corp 12
Boink 1973 Marcos MINI Spotted 1
6 Mini in Groveport Spotted 0
Steve Mini photos... British Motor Corp 6
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
J Funny noise in my mini British Motor Corp 12
Steve A Mini that is not what they are saying it is British Motor Corp 18
Mickey Richaud Mini Midas? British Motor Corp 1
Mickey Richaud Mini Midas? Other British Cars 4
R Tyres for Mini Cooper British Motor Corp 7
J Seaching for former owner of my Mini British Motor Corp 0
Boink Split Mini British Motor Corp 0
U Mini Cooper S Roadster ! British Motor Corp 1
