Edward:
I was having problems with my S.U.'s so for simplicity sake I went to the Weber. Got it running the night I installed. I went to start up the next morning and she spit and sputtered. Seems if I give it full gas for awhile I can get her to level out but in a very short period of time I stall. Perhaps a float adjustment but it's a new Weber and I wanted to avoid that. It almost seems to be flooding out. I was stalling at idle on my old set up then it got worse. Fuel line seems to be cleared but perhaps the feeder in the tank is clogged a bit. I have a relative that could never figure out why his midget was stalling and it ended up being a rusted tank feeder valve (the part of the fuel line that is in the tank, not sure what its called). The electrics checked out fine but I believe that the timing needs to be advanced a bit with the new Weber, at least that's what I have read. My fuel pump is rated at 5- 9 psi and I don't have a regulator on it. With all that being said, I thought I'd go to a lower pressure fuel pump. A friend of mine that runs a Cobra suggested that the fuel pressure could be blowing past the bowl and flooding her out. Ironically my post is next to an older post of fuel pump which make me believe I'm getting to much pressure. My friends suggest that a fuel filter be put on both side of the pump. Let me know if you figure it out. I'm going to get a lower pressure fuel pump tomorrow and give it a try.
Mike
