Fuel pump rating for Weber DGV Carb?
M
Mike
What PSI rated fuel pump should I use on a Weber DGV carb for my 1275 series A engine. I am currently have a 5 to 9 PSI rated fuel pump that I am changing out.
Thanks,
Mike
1958 Bugeye Sprite
You won't need anymore than 3 psi. It's about the same as an SU in that regard.
Thanks aeronca65t. One question, would a pump putting out up to 9 psi cause a problem? I am questioning the existing fuel pump I have in place with to much pressure to the bowl and blowing past the inlet causing a fuel issue.
Thanks,
Mike
Edward:
I was having problems with my S.U.'s so for simplicity sake I went to the Weber. Got it running the night I installed. I went to start up the next morning and she spit and sputtered. Seems if I give it full gas for awhile I can get her to level out but in a very short period of time I stall. Perhaps a float adjustment but it's a new Weber and I wanted to avoid that. It almost seems to be flooding out. I was stalling at idle on my old set up then it got worse. Fuel line seems to be cleared but perhaps the feeder in the tank is clogged a bit. I have a relative that could never figure out why his midget was stalling and it ended up being a rusted tank feeder valve (the part of the fuel line that is in the tank, not sure what its called). The electrics checked out fine but I believe that the timing needs to be advanced a bit with the new Weber, at least that's what I have read. My fuel pump is rated at 5- 9 psi and I don't have a regulator on it. With all that being said, I thought I'd go to a lower pressure fuel pump. A friend of mine that runs a Cobra suggested that the fuel pressure could be blowing past the bowl and flooding her out. Ironically my post is next to an older post of fuel pump which make me believe I'm getting to much pressure. My friends suggest that a fuel filter be put on both side of the pump. Let me know if you figure it out. I'm going to get a lower pressure fuel pump tomorrow and give it a try.
Mike
I'm riding your coat-tails on this one! Mine is very similar. I can only get it up to 2400 RPM, then it completely cuts out. I rebuilt the carb and checked all the jetting and float levels and it didn't change a thing. You'll probably get yours going quicker than me, so I'll wait to hear how it goes. Thanks for the info!
Thanks,
Mike
Yes, absolutely. I once bought a car with an unregulated Facet pump and Weber DGV. It was flooding like crazy until I fitted a fuel pressure regulator.
My present vintage race car will flood if I turn the regulator up to 6 psi (I race at around 3 psi).
By the way, I'd recommend the Holley fuel pressure regulator sold at Summit Racing.
T TR2/3/3A fuel pump oil leak Triumph 7
M MGB Fuel pump Banjo fittings MG 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
