SU Fuel Pump Mounting
T
twosportscars
Hello I have a BJ8 Phase II. The car had an aftermarket fuel pump from New Zealand that finally gave out. It was made of plastic and was just hanging on the metal fuel lines. It was not mounted to the pump bracket. I just bought a genuine S.U. pump (made by Burlen apparently) from Moss Motors.
My question is around the mounting bolts. I have a couple of old Whitworth thread bolts of the right diameter, but they go in only about a turn and then stop. I have visited Home Depot and Napa and looked at all kinds of bolts, but nothing fits. Does anybody know exactly what bolts and threads per inch are required for this pump? The model is AZX-1307.
It looks like Moss does not list these mounting bolts as a part number that can be purchased.
All the SU pumps I've seen--and I have at least a half-dozen--were mounted with studs (it's much easier to start a nut than a bolt). Yeah, the thread is weird, not SAE and I don't think they're Whiworth, but SU Burlen indicates that's what's used:
What I do is tap the holes with an SAE bottoming tap--5/16" I think--and install an off-the-shelf SAE stud with some JB Weld to fill the threads. If you can get studs with coarse threads you won't spend 10 minutes securing the nuts on the side of the road when you have to swap a pump.
Or, you can call BCS or Tom's Import, etc., and see if they have some of the right-size studs
T
twosportscars
Thanks Bob for this quick reply. It makes a lot of sense that it uses studs. I just didn't have the original parts as a reference. As I think about it, these studs could be very similar to the ones that mount the carbs to the manifold, which seem to have a bit of taper to them. As you say, it makes those roadside tech sessions to swap out a pump a lot easier.
I'm not familiar with BCS -- what does that stand for?
In any event this reply is very helpful -- I was barking up the wrong tree!
JoeCA
Member
Moss doesn't sell the stud, but they offer a bolt with the correct threads. If you look under fuel pump mounts, they show the stud as part #9 (stud pump to bracket) and the bolt alternative as part #10 (bolt - alternative to stud part 320-360). I used the bolts to mount the SU fuel pump on my BT7. A spacer was required so that the pump cleared the mount. The BT7 uses a different mount than your car, so the spacer may not be necessary.
Joe
T
twosportscars
Thanks Rob and Joe for these latest updates. Now I see it in the Moss Catalog as Part #10 but I went ahead and ordered them over the phone with John at British Car Specialists. A good learning experience for me. This should take care of it. Thanks to all for the advice.
-- Paul J.
catfood Mounting a BN1 fuel pump Austin Healey 6
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
T Quick fuel pump question - mounting angle MG 3
Moose33 aftermarket fuel pump mounting help? MG 7
R TR2/3/3A Fuel pump? Triumph 11
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
