Weber Carb Rebuilds
msoylemez
Hi,
I was wondering if anyone knew of a good weber carb rebuilder out there? Mine are not in bad shape, but have been sitting for about 10 years and I'm sure they need to be rebuilt (and cleaned up would be nice).
Is there someone in our community (AH spridget) who specializes in these? Like Peter at WorldWide Auto specializes in level shocks, etc--that sort of thing.
I'm in So. Cal, but would obviously be willing to ship wherever.
Thanks.
Mustafa
Biff
Other than a good cleaning and a new gasket kit you can do it yourself. There was a web site (Weber dealer) that had an exploded view of the carbs with a parts list. Use that to strip the carb down to it's basic componets and clean everything and reassemble with the new gasket kit and you are ready to go. The same web site had tuning instructions also. Otherwise be prepared to pay............
msoylemez
msoylemez
Thanks Biff.
Should I just douse everything in regular old carb cleaner and use a brush to clean?
And what about jets and tuning? I guess that comes after the carbs are on and you are adjusting everything?
Biff
Yes. Strip it down to it's parts, soak in a can of carb cleaner, if you have air blow dry it and with the correct diameter wire check that all the passages are open, and reassemble. The only jetting, choke, excellerator pump changes that 'could' be made before installing it would be for those that are totally incorrect for your application. In the Weber books they give all the settings for a 'particular' motor which you could check your internal parts against. However, these 'settings' are only a guide.
lesingepsycho
Get yourself a one gallon can of "Chem-tool Carb Dip". It comes in a can that looks like a white paint bucket with red and blue writing on it and they include a parts basket for dunking parts. You can find it at almost any auto parts store. The stuff can be used almost forever because it doesn't evaporate, it just desolves crud. I've got a gallon that I have had for more than a year and I have rebuilt coutless carbs with it. Then, like anything else, you take everything apart, replace the gaskets and rubber pieces and put it all back together. It really is that simple. The hardest part I would say is setting the mixture once it is back on the car but with a Weber, that is only a single set screw and is pretty easy. That's what makes the Weber so great!
JACK
jlaird
Bah, SUs are easy, and when adjusted stay that way for years.
S Weber carb set Other British Cars 7
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
P For Sale Weber carb/intake, header Spridgets Classified 2
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
M_Pied_Lourd TR2/3/3A Weber Carb Installation Question Triumph 13
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
L Best electric fuel pump for Weber DGV carb Spridgets 10
L Electric fuel pump for Weber DGV carb Austin Healey 3
E 1977 Midget Weber carb FORUM Navigation Questions 0
E 1977 Midget Weber carb Spridgets 1
R Weber carb hang-up at high rpm MG 0
M Weber Carb trick Spridgets 1
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
T MGB 1979 MGB with Weber carb MG 7
M Fuel pump rating for Weber DGV Carb? Spridgets 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
B Weber Carb tunibg MG 2
pjsmetana Weber 32/36 DGEV Carb Triumph 6
DarwinT Adjusting a Weber carb Spridgets 3
DarwinT Weber carb and possible vacuum hose Spridgets 10
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
H Alfa Weber Carb Porn Other Cars 2
58Custom Seek opinions/experiences w/ Weber 32/36 DGV carb Spridgets 4
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
PAUL161 Weber Carb Diagrams & Parts Lists. MG 0
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
T Weber DG carb jetting question Spridgets 16
G Vacuum advance with Weber carb, some tuning issues Spridgets 8
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
H Junkyard B with Weber carb MG 4
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
C Weber carb conversion AH 3000 Austin Healey 3
Monark192 Weber carb pic request MG 31
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
J Setup for single Weber carb Spridgets 4
J weber DCOE 45 carb a bad idea? Triumph 5
S Weber 32/36 carb trouble! Other Cars 16
C Newbie Tech Question- Weber Carb Spridgets 10
mylillooker Gulp valve, Weber carb Spridgets 4
E Weber Carb performance MG 23
A Weber Carb meets hood... Spridgets 3
R6MGS Weber Carb Parts...HELP! MG 4
L Weber Carb Kit on Ebay Spridgets 0
J Sprite Weber carb question and problem! Spridgets 9
