TR6 Possible rebuild of SU-HS6 Carbs for TR6
jmayled
I've recently acquired a set of used SU-HS6 carbs that I would like to install into my '75 TR6 in place of the ailing Zenith-Strom's.
The SU carbs are stamped with "AUC 1346" and "AUC 8490". Is it possible to rebuild these carbs for use with a TR6?
If so, can anybody provide me with some good pointers? (A copy of the Haynes Weber / ZS / SU Carb Manual is en-route to me.)
Best Regards,
Jon.
I've just replaced my old and worn ZS carbs with a newly rebuilt pair of SU-H6's. These are a direct bolt-on replacement for the original zeniths. Rebuild kits are available but I had mine done professionally by Jeffrey Palya. He does good work and micro-polishes the units to better than new (see photo). https://paltech1.com/index.html
WOW those look great. Do you know what he uses to "micro polish" them. It also looks like he plated all the hardware.
HI Jaymayled, There should be two small aluminum tags fastened to the top of the float bowls with the carb type number on them. However, you will have to match the carbs to your engine because as far as I know the SU is not original to the TR cars.---Fwiw---Keoke--?
Hello Jon,
S.U. HS6 models were fitted to the following Triumph cars, which use the TR6 engine:- 1975\76 2500 TC. they used the BDB needles, part no NZX 8002 or a BDU which is NZX 8019.
For more detailed information try this site:- www.burlen.co.uk, who manufacture and supply S.U. spares.
Alec
i have put hs6's on my tr6. here is the deal, any hs6 will bolt up to the manifold, the difference is in the float chambers. the ones you need, need to sit level, not on an angle like most do. you need a set of floatbowls from a spitfire or give apple hydraulics a call as he normally has some in stock. it will work if you use the floats that do not sit level, but as they do not sit level they will always force some fuel into the carb and make it run rich.
Randy
tr6lover,
i don't follow the issue of float bowls not sitting level. sure, the su float chambers can be tilted to accomodate fitment but how does this affect the amount of fuel flowing into the combustion chamber? seems that the fuel flow into the carb is controlled by the metering needle and jets which should not be affected by a slight angle on the float chamber. i can see this having some play in the float and shut off valve at the top of the bowl but this does not impact fuel flow into the carb so long as fuel is available in the chamber. pardon if I'm not clear on this.
HI Piman, I could not get Burlen's site up. But what ever HS6 carb type they show for the TR6 engine our lister[Jon] will be required to duplicate using the ones he obtained.---Keoke
Hello Keoke,
I just checked the link and it worked for me just now. It could have been down when you tried it?
That is the point, although there are few major variations in practice. Needles are one, and as mentioned the float bowl adaptors, which set their angle is another. Burlen will have the correct specifications, but I'm sure that there must be other specialists in America who can advise and supply the necessary parts. The above plus overhaul kits weigh next to nothing so shipping is not an issue.
Alec
Hello all,
further to my last post and as I had the Burlen site up I looked further and they list a conversion kit for the TR6 from Strombergs to SU. Their part number is FZX 3045. A full list of the components is:- https://www.burlen.co.uk/partList.aspx?carID=9647
The needle they have for this conversion is a BAG, which is part number CUD 1106.
Alec
[ QUOTE ]
tr6lover,
[/ QUOTE ]
FWIW I have the TR3 type SU H6 (not HS6) with the cast twist in the floatbowls. It looks a little odd but works OK. I had to seal the lids with some sealant because the joint tends to be wetted by the fuel more in this configuration. Pete
hi all, the issue with the floats sitting level isnt just a matter of getting the correct adapters, the fuel level in the floats that sit level is much higher than the ones that sit at an angle and even if you make the ones on an angle sit level then the float height is too high and therefore forces fuel into the jet and right out into the carb. the tops are the same but the level float sits lower so it doesnt force fuel into the carb thats why it would run rich if you just used the floats you have. give apple hydraulics a call and joe curto can explain this all to you.
Randy
the adjustability of the float bowl angle on SU carbs is there to compensate for the natural angle of the carb mounted on the intake manifold. ie..the carb is naturally tilted so you adjust the float bowls to level.
regardless, the function of the floats is exclusivly to open and close the valve from the incoming fuel line. it has nothing to do with richness of the fuel mixture or even flow into the carb itself. that is managed by the throttle, jets and metering needle. if your carbs are running rich it is not an issue with your float bowl. so long as there is fuel in the bowl and it is not overflowing then your float valves are functioning correctly.
Hello Randy,
the idea is that the float chamber is always vertical, whatever the angle of the carburettor and the level is always the same.
Alec
the point i am trying to make here is that when you stand the float bowl up the fuel level sits higher, a lot higher than the floats made to sit level. you can not adjust the float enough to compensate for this. since the fuel level is much higher it forces the fuel into the carbs because of the fact that the jet is now sitting lower than the level of the fuel so it is being force fed into the jet. this is a problem and i have seen it first hand. i have talked to quiet a number of people who have done this conversion and this is always the case. the mount for the float bowl is in a different position on the floats that sit level so the bowl sits lower on the carb than the ones on an angle.
Randy
[ QUOTE ]
[/ QUOTE ]
nope.
Take a funnel and a hose and hold the end of the hose higher than the top of the funnel in a U.
fill it with some water. As you raise and lower the funnel (The float bowl) the level in the hose (the jet) goes up and down.
The function of the float is to ensure the proper level of gas at the jet. If the float is too high then the gas wants to seek the level of the float and you have more fuel than designed at the end of the jet. if you look at it with the top off the carb you will see the fuel just sitting to the top of the jet.
Yes there is a vacuum through the bore but I'm of the understanding that fuel getting to the jet is more a function of gravity rather than suction.
Thank you all for your feedback. Above the AUC numbers stamped in the body of the carbs, there are no other identifying tags present. My assumption here is that as these carbs have a 1 3/4" opening, they are definitely of the HS6 family, however I would still require the correct needles and a general rebuild kit assigned to the '75 TR6. Can anyone clarify this for me?
In lieu of that and based on the possible complexities with rebuilding these older model SU carbs, I may ship them to Paltec for a professional rebuild / trade-in. (Jeffrey Palya's craftsmanship looks exceptional!)
Thank you PIMAN and 71TR for the web links.
Hi, I have the HS6's on my '74. I was able to take the float bowls off, and remove a piece that looked like a pie slice if I remember correctly. Then I put them back together with this peice reversed. It removed the tilt and they are very nearly level. I haven't changed the needles and they probably need it as there is a flat spot. Other than that they are great. Perry
[ QUOTE ]
[/ QUOTE ]
If you post a pic of the carbs you have, or just a good shot of one of them, it would help give a positive ID on what you have. If they are 1.75" SU's they are definitely XX-6, a question would be what is the XX and anything specific to do with the application (which vehicle they came off). Pete
The carbs from what I can fathom are from a Volvo P1800. Hopefully someone maybe able to clarify the carbs from the attached pictures?
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
R Possible Midget purchase - advice needed Spridgets 11
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
