TR4/4A TR4A Temp Gauge Scale
RJS
Hi All
Mine is a 1966 TR4A with a Jaeger water temp gauge. Does anyone know what temperature the readings on the scale equate to? I am pretty sure the center of the gauge corresponds to 185*F (normal). How about 3/4's and (most important) the edge of the "red" zone on the far right?
Thanks
Bob
Sarastro
I don't think you can generalize, for a number of reasons. One is that the sensors we get today are different from the original ones. In any case, I don't think that 185F is the center of the scale, at least not on mine; mine sits at about 2/3 scale, and I don't think that is much more than 185.
If you really want to know, you could remove the gauge, sensor, battery, voltage stabilizer, and calibrate it in a hot-water bath. Or, just the gauge and sensor and borrow a variable-voltage power supply for it; set it to 10 volts.
But why do you feel the need to know? It would just tell you the water temp at one point in the cooling system--what can you conclude from that? As long as you know where the temp meter needle sits in normal running, attaching a number to it doesn't really tell you much more.
TRopic6
Hi Bob, FWIW, the TR4 temp gauge has 70 (Cent) at the bottom (168F) and the 4 & 4A used the same transmitter.
Sarastro
Whattaya know, I remembered that I had done a hot-water cal on my temp gauge. I used a laboratory DC power supply set to 10 volts and calibrated the gauge with two sensors. The first is the one that came on the car; the second is a new, Lucas replacement sensor.
Hope this is legible, but I didn't want to take the time to recopy it; it is a scan of my project notebook. The left column is the temperature and the right is the percentage of full scale, including the cold and hot zones. Ignore the middle column.
This may or may not be valid for your gauge and sensor. No guarantees, but maybe it's still interesting.
I eventually chose the Lucas sensor, as the reading with the first one was into the red zone at reasonable temperatures. But the results with both were similar.
RJS
RJS
Thanks Gents,
Steve, your notes are helpful. I am less concerned on what my gauge actually reads. What I am really trying to determine is what temperature Standard-Triumph considered "hot" - i.e. in the red? I have no proof but, it seems Std-Triumph calibrated the "edge of red" at ~205*F, with full red representing ~212*F (the boiling point of water). Please let me know if you agree/ disagree...
From my understanding, water temp is really not a concern, so long as the engine doesn't boil over. Having said that, I am running 50/50 water/coolant with a 7lb cap. That puts boiling at/about 230*-240*F. Suffice to say, if the engine and cooling system are in good nick, I should never see those kinds of water temps under street use. However, I suspect many Triumph owners become needlessly concerned when their temp needle moves off the middle to the right - believing the engine is overly "hot". However, I think the point of the gauge is not to indicate the engine is running hot but, rather, your coolant is getting closer to potentially boiling over - which is the real concern. But, up til the point of boil over, all is OK.
Last, I've done some less scientific measurements but, when my temp gauge is exactly in the middle, using an infrared temp gun I measure 185*F at the radiator tank inlet.
On a slightly related topic, I'd be interested to get some data on oil temps...
Regards
Bob
Sarastro
Yes, I think that's all is correct and makes sense.
From my notes, you can see that the edge of the red zone was 196 deg with the "original" sensor (i.e., the one that came with the car) and 205 with the new Lucas sensor, which I'm now using. The latter makes sense to me. My engine runs around the 2/3-3/4 point in ordinary use.
TR Tom
Member
It always really bugged me that a maker of serious sports cars would go from a really useful mechanical gauge with lots of numbers, in the TR3, to one with just one (centigrade) number, and then none at all. To make matters worse they fed it with an unreliable electrical sensor. This was the functional equivalent of the temperature gauge found on Ford Falcons of the era.
After a multi day trip in 100+ degree temperatures where I had no idea what was going on under the hood I finally took action. In addition to performing every cooling system upgrade possible (another subject for another thread) I went and bought a Stewart Warner mechanical gauge, which fit perfectly in the old hole. I now know exactly what’s happening temp wise, even with the key off. The black and white dial and font fits in with the other originals, although I did also replace the oil gauge just to balance things out. One of the gauge restorer’s said he could even put original TR style bezels on them, but now that I’m used to the look, I’ll probably never get around to it.
Anyway, that’s my solution. My TR4 will never win a concourse award, but I’ve always been more of a function over form guy.
Tom
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
