General Tech Yes, the Horns Again--Electrical TR4A
KVH
To start, I have good ground up the column to the horn button. I also have power to the horn relay. I cleaned up the relay points. But still no horn. I hope I haven't shorted out the relay--my new one from Moss has never worked. I keep it in a box, as if I can return it after 7 years. No matter what connection permutations I try, that new relay is a waste, so I'm using my trusty 56 year old British one.
Some questions: a) does the relay casing need to be grounded? I can't tell if something internal might rely on another ground even though the purple and black wire to the horn button is grounded when I push the button; b) it appears the relay is upside down. I see W-1 stamped below the connector, and of course it looks like M-1--sound right?; c) does it make any difference which wire goes to which spade connector on the horns?; and d) can I somehow bypass the relay just to hear the beautiful sound of my horns? At least I'd know the old lady is awake.
Any other advice on this? Thanks in advance.
poolboy
If you can put 12 volts on one of the actual horns spades and ground the other spade, the horn should sound if it's working.
Where you just need a 12 volt positive source, a few amps and a negative connection I use a battery charger to test things like that.
As far as the relay...if you get 12 volts coming out of the C1 terminal when you depress the horn button on the steering wheel, it's probably wired correctly and the relay is doing it's job.....If not go back "upstream" and see what's going wrong.
KVH
KVH
Got it! Fixed. I researched prior posts and found that for the new relays you have to jumper posts C-2 and W-2. Now we all know, again I guess. Anyway, all good.
KVH
KVH
I really shouldn’t leave this subject without first asking you folks who understand “electrics”—why must we jump C-2 with W-2 when installing the newer horn relays?
Geo Hahn
I suspect it's because you're asking the relay to provide a ground (whereas most relay applications are done to provide power).
But that's a guess and I've already had my second glass of wine so consider the source.
Sarastro
I think it's because W2 and W1 are the coil, and C1 and C2 are the switch contacts. In the original relays, the W2-C2 connection must have been made internally, so there was no external W2 contact. In the newer ones, it appears that the internal connection doesn't exist, so you have to make it externally.
Frankly, I'm done with using those old relays in cans. The final straw was when the internals of one shorted to the can body and blew my horn fuse. You can use ordinary, modern, Bosch-type automotive relays in place of them, and they are more reliable and cheaper. In those relays, terminals 85 and 86 are the coil, corresponding to W1 and W2, and 30 and 87 are the normally open switch, corresponding to C1 and C2.
Popeye
Bronze
Basically, you jumper W2 (85) and C2 (87) to provide power to both.
Pushing the horn connects W1 to ground - completing the W1-W2 circuit, which in turn closes the C2-C1 switch. C1 connects to the horn, in turn which goes to ground.
In a normal relay install, the W2 power input comes from “far away”, eg a light switch, and the intent of the relay is to reduce current on long runs of wire / frail switches. However, I’m this case the input power is “local” and the ground is “far”. Thus both sides of the relay can get power from the same source - the jumper.
(I’ve been studying relays and OD wiring, figuring out how to add a diode…. Not saying I’m right, but I have a few schematic sketches in front of me and just placed an order with British Wiring and Digital-Key.)
Rod-H
Bronze
If you connect them backwards, they will literally suck sound right out of the air. ;)
Popeye General TR Battery Tray - yes or no? Triumph 11
T This is going to be a huge amount of work, yes? British Motor Corp 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
JPSmit Yes Please! Spridgets 0
Rob Glasgow Healey 1000/4 yes 1000/4!! Austin Healey 5
Rob Glasgow Healey 1000/4 yes 1000/4!! Austin Healey 0
Jim_Gruber Bugsy IV's First Drive - Yes He is Legal and now on the road Spridgets 12
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
M TR4/4A Underhood/Bonnet insulation...Yes...No ? Triumph 3
JPSmit Yes, I know it is a Kit Car Other Cars 1
drooartz MGB Yes, I drive with the top up MG 5
luke44 TR2/3/3A TR3 Center Mirror - Support Bracket. Yes or No? Triumph 7
T Yes, I have too cars. Sidescreen help Triumph 14
AH67 How to open hood? Yes i'm serious. Austin Healey 5
Tr3aguy Stripped parts...yes Triumph 8
M this carb set up, yes or no Spridgets 11
QuickSilver Yes, I'm A Glutton For Punishment Rover / Land Rover 6
RickB Seats Sprite Mk II / Midget Mk I [yes, again] Spridgets 23
T Ratcheting wrenches! YES! Restoration & Tools 23
T Yes, Virginia, there is a Santa Claus Triumph 7
B Have mercy..am I insane?? Yes! Spridgets 22
C Supercharged Jag V-12 in a Healey 100? - YES! Austin Healey 1
timbn2 Are these 100-4 seats... yes or no? Austin Healey 8
kodanja TR4/4A New TR4.....? yes /no... Triumph 5
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
Bret Just say YES to Roadsters! Other Cars 9
B TR6 Yes.....another TR6 tire size question Triumph 7
TRclassic3 Yes, another high idle string Triumph 21
zimmy Rustoleum......yes, once again...... Spridgets 42
Atrus Yes, another electronic ignition question Spridgets 2
B New Midget, Yes another one Spridgets 51
kyreb1862 Next Question.........Oil Coolers [Yes or No] MG 10
Brosky Pacesetter Headers Yes or No? Triumph 13
jaybird Yes! Engine's done! MG 42
G YES!!!!!! I WAS RIGHT!!!!! Triumph 2
t8nwa NEW, yes new, Triumph car rumor Triumph 31
Steve_S Dodge Challenger. Yes, Dodge Challenger. Other Cars 33
bluemiata90 TR2/3/3A TR3A rack and pinion conversion-yes or no Triumph 8
Jim_Webby TR4/4A Free [yes, free] TR4 available in Michigan Triumph 31
J connie chung's car [yes, THE connie chung!] Austin Healey 9
P TR4/4A Birch Grey TR4A .... yes or no ? Triumph 19
Sherlock Yes... we have some nice cars in the frozen north Other British Cars 9
P lighten flywheel - yes or no ????? Triumph 4
KVH General Tech Horns Triumph 8
KVH General Tech Horns Triumph 10
R Bugeye dual horns Spridgets 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
S Wanted Wanted - TR3A Horns Triumph Classifieds 2
red57 Lucas 1748 horns Austin Healey 19
red57 Wanted WTB Early Austin Healey Horns Austin Healey Classifieds 1
