TR6 Milling the head
Buckshot57
getting ready to reassemble the engine. Cylinders are.020 over, plan on using the BP2 camshaft. Any suggestions on milling the head? How much?
Where to set the timing?
I have the triple Weber set up but feel like it might be more than needed. Thinking about using the Strombergs that were the original carbs. Any input appreciated. GO 🇬🇧
mctriumph
On my 71, I had .125 taken off to get a 47cc chamber.The machinist was agast"thats an eighth of an inch"
Well the factory added metal to "achieve lower compression" and it needs to come off.Try for
9.5/1 . Do a little work on the intake ports. I liked the tri carb setup from good parts just added a Stromberg
More $$ and I would have done 3 SU;s
Mad dog
charlie74
I used Richard Goods website (> Good Parts | Custom TR6 Parts <) to determine compression ratio vs head thickness to also get a higher compression ratio. I didn’t go quite to 9.5:1 because I wanted to leave a little incase the head needed removal again and it could then be decked for flatness. I am using the original twin ZS carb setup with a BP270N cam which works well. I don’t find the car to be starving for fuel at all…but the triple weber setup is eye candy!
I’m not sure how the BP2 and my cam compare but mine is a Newman cam and it came with it’s own timing instructions.
B
Buckshot57
Thanks for the input. I’ve done a lot of American made engines but I’m learning a lot about the Triumph world and enjoying it.
I’ve seen Newman cam mentioned before. I take that it’s a quality cam. Who’s the best vendor for the BP270
malbaby
Suggest you measure the volume of the combustion chambers first, otherwise you can not be certain of the desired compression ratio.
charlie74
That’s a bit subjective perhaps, but I bought mine from and have had pretty good luck with British Parts Northwest (bpnorthwest.com). Richard Good’s stuff is very well regarded but spendy. If you’re into modifying your car he has lots of drool worthy things on his site…
T Milling a head on a Stock 1275 for compression? Spridgets 13
wangdango BJ8 door hinge milling? Austin Healey 2
D Block milling Austin Healey 5
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
