TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle
DennisT
I installed a gp2 cam, had the head shaved , got shorter pushrods, experiencing a rough idle, I went through the timing and had degree the cam 8 degrees BTDC. I did a smoke test and not aware of any leaks, the compression is uniform @160psi on each cylinder. the vacuum reading is bouncing between 15 and 16, the idle is random plus or minus 50 rpm. Carbs appear to test lean and I have them adjusted full rich. I ordered the richer needles from Curto and will try them this weekend. I read some posts about the distributor needing its curve adjusted due to the cam change. Any help would be appreciated
Dennis
poolboy
Was the cam timing advanced 8 degrees ?
That's what it looks like you wrote.
If so why so much ?
mctriumph
Welcome to the rabbit hole!! AKA slippery slope. Not sure what you did on the cam install. Hope you did NOT advance it 8.deg
usually + or - 2 deg depending on the desired torque needed. But now on to the crabs...... Two is not as good as 3 for a host
of reasons. Lose the old intake and add one more Strom. Even better 3 SU's. Weber's are too much unless choked down a lot.
You need an experienced carb man to even get close with this motor.Make double sure you have no intake leaks, Header??
MD
charlie74
Verify your valve lash is set correctly. The BP270 cam (a Newman cam) has a valve lash of 0.014” (I) and 0.016”(E). I just went through this with mine; once it was set properly the idle smoothed out nicely…
poolboy
I timed my cam to 4 degrees BTDC.
My cam is the stock 311399 cam that was in the 73 thru 76 TR6 engines.
You may want to discuss things with Richard Good since it's his cam, though.
DennisT
He said the straight up gp2 cam timing is 3.5 btdc, he says to have the number two lifter at .050 lift, is that what you would do?
Dennis
poolboy
Yes, I would do exactly what Richard said, just make sure you have a good understanding of his instructions.
He won't mind if you have more questions..
If you get that right and still have problems at least you'd know it wasn't the cam or cam timing causing problems
DennisT
This is a picture I took today with the first intake lobe at .050 lift, the damper indicates 16btdc, is that marker accurate and would it be able to run with that much advance?
poolboy
Was that where it was when you wrote that first post ?
As far as the question of accuracy of the timing marks, you'd have to determine that...I use the piston stop method for that. Turn the crank ClockWise until it stops then mark the damper ...CounterClockWise until it stops, mark the damper... and TDC is in the middle of the marks.
DennisT
Hi,
I did 015 on intake and 017 on exhaust lash and was able to adjust the cam sprocket to 6 degrees , since the straight up timing on the gp2 is 3.5 , R GoI’d said that would be fine. I did check td on the damper with a rod in #1 plug hole and it was dead on. Also the mark on the timing chain cover was accurate. I must have made a mistake when I put the degree wheel on the crankshaft when I used the piston stop. I had the head off and used the piston stop with a dial indicator. Any way I put the motor back together and started it up. I attached a movie file below. Whe I was trying to synch the carbs, I could not get the front carb to pull any air. Not sure what is causing that. The engine starts and runs smooth when you goose throttle but still has a little stumble and will only idle at about 1700 -1800.
it seems to run better the longer I ran it. I can’t attach video Sorry
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
H TR2/3/3A TR3 head /cam Triumph 4
J Cam, head and other stuff from the PO Triumph 4
beaulieu MGA MGA twin cam head on non twin cam motor ? MG 9
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
T TR4/4A Core Plug - Cam Rear change Triumph 7
D cam bearings Austin Healey 23
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
E TR6 Some cam questions Triumph 9
steveg Denis Welch mild cam Austin Healey 9
B Twin OH Cam for the BIG Healeys Austin Healey 15
K TR2/3/3A Street cam again and Valve gap? Triumph 6
K TR2/3/3A Mild street cam and Idle? Triumph 13
T Spitfire Cam shaft Triumph 3
J MGB MGB cam, gear? MG 3
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
Marvin Gruber Cam shafts for 3000 Austin Healey 2
K Kastner "F" race cam. Racing 3
