TR2/3/3A Triumph TR3 cam shaft measurement
jfcdo
Is there a way to measure a TR 3 camshaft to see if it is worn to where is needs to be replaced?
I'm wondering if the cam shaft that I have is still good or do I need to replace it.
The most sensible thing to do is to just replace it, but if I can avoid that cost, I sure would like to.
I want to make sure that the one that is have is still serviceable before I install it.
This car would be a weekend driver and not set up for racing. I want to keep it simple.
If I can measure it, what should I be measuring and what should those measurements be? Cam heights? Journal diameter?
Any suggestions are appreciated. Thanks.
TR3driver
Great Pumpkin - R.I.P
For a driver, I would just do a visual inspection. If there's no obvious damage, it's almost certainly good enough.
Here's a short explanation of one way to check the lift
https://itstillruns.com/measure-camshaft-lift-7596793.html
(The dial caliper shown will work fine, even though the text specifies a vernier caliper. Digital will be fine too.)
CJD
When I measured mine, it had .260” of lift at the lobe. Run a caliper on each lobe to ensure they are within a couple thousandths and you should be good. When cams go they usually grind the lobes flat.
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
D 1957 Triumph Tr3 Triumph Classifieds 2
banjojambo Triumph tr3 vertical link wobble Triumph 2
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
J Wanted Re: WANTED TO BUY: TRIUMPH TR3 ASH TRAY PULL KNOB Triumph Classifieds 1
K For Sale Triumph TR3 Blanking Plate Triumph Classifieds 1
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
Kleykamp For Sale 1961 Triumph TR3 Triumph Classifieds 0
K For Sale Triumph TR3 Water Pumps for Rebuild Triumph Classifieds 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
H TR2/3/3A Triumph TR3 Hand crank alignment Triumph 21
Hap Waldrop TR6 New VTO15x6 in for the Triumph TR3-TR6 Triumph 25
K TR2/3/3A TR3 Chrome TRIUMPH emblem fit Triumph 7
T TR2/3/3A Triumph TR3 Windscreen Restoration Triumph 6
F TR2/3/3A Triumph TR3 and others Triumph 8
B TR2/3/3A Triumph TR3 Ebay Triumph 10
toysrrus TR6 `58 Triumph TR6 or TR3? "The Scammer is back"! Triumph 2
mine TR2/3/3A Pictures of Triumph tr3 from Mine Triumph 1
S TR2/3/3A Triumph TR3 Posters Triumph 8
J TR2/3/3A ROYZE Carburetor Kit SU963 Triumph TR3 Triumph 1
M TR2/3/3A TR3[FELLOW TRIUMPH OWNER]HELLO!! Triumph 0
B TR2/3/3A TRIUMPH TR3 FRANCORCHAMPS... for sale Triumph 6
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
