Denis Welch mild cam
Just got mine a couple weeks ago and haven't had it installed, yet. Will say it looks like a sweet piece of engineering and construction, and the speed shop building my engine was impressed. It's supposed to be 'slightly better than a stock BJ8 cam;' the spec sheet--I think it's on the DW site somewhere--shows just a but more duration and lift. Note it comes as a kit; you have to choose standard or bucket lifters (included in the price).
The DWR guys are online during normal business hours in the UK, and are helpful. Tell 'em I sent ya ;)
John Turney
Steve,
As you know, DWR has supplied me with much info and parts. They are also the first sponsor to International Healey Week 2017, so I give them high marks.
My cam is the DWR-8 cam requiring the pockets, so I can't help with the mild cam.
DerekJ
Steve,
What set up do you currently have? Is it the standard 100-Six cam with twin 1 3/4 inch carbs? If so then you should notice a nice improvement with the DWR 'mild cam'. On the other hand I had the DWR8 cam with twin 2 inch carbs and found that to be a terrific combination for a fast road set up.
steveg
steveg
Steve,
Derek - I have a Mk1 3000 engine with hi-lift rockers, HD8s on a DMD manifold and Kirk tube headers. 28% Toyota trans on 3.54 axle.
How do you feel the DWR8/HD8 setup does with keeping low-end torque?
GregW
Hey Steve,
Since you have high lift rockers, Denis Welsh's claim of no pocket ports needed may be negated. Not unail the math is done with their cam dimensions.
DerekJ
The DWR8 is very good at keeping low end torque. Its good from about 1200 revs, with a flat torque curve. The DWR2 rally cam is not so good at the low end but delivers more power higher up..
John French
I just got mine running after installing one of those cams but have to finish off some other items before being able to drive it. One thing I had to do was get a vernier sprocket to get it to time up correctly so it ended up being a considerable investment.
I'm about 15 miles west of you if you'd like to hear her run.
WHT Denis Welch CENG635SO Flywheel Austin Healey 0
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
H Denis Welch cooling fan arrived today Austin Healey 2
V Denis Welch Austin Healey 5
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
J Denis Welch STEEL ROCKER PEDESTALS AND SPACERS Austin Healey 1
Roger Denis Welch RIP Austin Healey 12
Patrick67BJ8 Denis Welch Air Filter for BJ8 Austin Healey 22
M Denis Welch Vernier Cam Sprocket Austin Healey 8
stretchit2 Denis Welch Steering Box Austin Healey 4
Randy Forbes Denis Welch 100/S brochure... Austin Healey 0
A Denis Welch Aluminum Head on a 100M Austin Healey 9
6 Denis Welch Brake Drums? Austin Healey 5
E Denis Welch Dual Circuit Brakes [BN2]????? Austin Healey 9
R Denis Welch Header Austin Healey 2
B Welch air filters Austin Healey 5
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
H Dennis Welch Cooling Fan Austin Healey 9
Frankenhealey Welch Endurance Car for sale Austin Healey 2
zschicago Installed Dennis Welch brake kit Austin Healey 5
HealeyPassion Impressive video Jeremy Welch racing in rain Austin Healey 7
6 Question re: Welch Brass Radiator Austin Healey 5
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
DerekJ Dennis Welch Headers - their view Austin Healey 7
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
K TR2/3/3A Mild street cam and Idle? Triumph 13
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
S Mild 'groaning' on clutch depression... Austin Healey 10
M Healey 3000 Mild Steel Exhaust good price Source Austin Healey 2
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
D T-Series Query: what's the best clutch kit - mild race? MG 9
Y Random Orbital Snader for Mild Restoration Stuff Restoration & Tools 11
