Mixing stainless and mild steel exhaust
Jeepster
I have a standard mild steel exhaust and wanted to replace the down pipes from the manifold.
The parts suppliers only has stainless units in stock so I ordered a pair.
I know that the different types of exhaust have different properties ( durability, noise etc) and that it's usually a no no to mate dissimilar metals, but any issues with joining a MS system to SS ?
Griz
Jeepster, if you are worried about corrosion you might Google "galvanic corrosion chart". Galvanic corrosion is the measure of how dissimilar metals will react when placed together in an assembly. The further apart the metals are on the galvanic chart indicates a greater potential for corrosion. And galvanic corrosion typically requires an electrolyte (like water) to accelerate the corrosion process. Mild steel and stainless steel are pretty close together on the chart so likely you will have few problems corrosion wise.
Griz
vette
I'm pretty sure that Moss has the down pipes in Mild Steel. But of course if you have already ordered some, I know I hate to return stuff. I don't think you will even notice any galvanic action.
Keoke
This application will most likely insure that the SS remains passive at all times and no galvanic action will occur.
stretchit2
Jeepster - I put in a full stainlees system in my car a couple of years ago and blew out a baffle in the muffler. I had not liked the sound of the stainless muffler so when I replaced the muffler I did so with mild steel, so basically the opposite inastallation you are considering.
In any case, I was just under my car last week and saw no signs of unusual corrosion. I live in So Cal, so not much rain or humidity so not to surprising. JEFF
mrv8q TR2/3/3A Mixing MT-90 with Hypoid Gear Oil? Triumph 13
TRMark Body Filler Mixing Board on the cheap Restoration & Tools 2
R Mixing spark plugs Triumph 10
T Mixing one and two post fulcrum brackets Triumph 3
B Mixing autobody products? My 2 Pence Restoration & Tools 0
T mixing oils Austin Healey 6
Webb Mixing Brake Fluid Spridgets 16
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
E Moss stainless exhaust offering. Austin Healey 28
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
J General Tech Stainless-steel caliper pistons Triumph 8
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
TulsaFred Polished stainless steel bumpers? Spridgets 13
S TR2/3/3A radiator pipe in stainless steel Triumph 5
T Rattling stainless muffler Austin Healey 10
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
bighealeysource Installing new stainless steel beading on BN2 Austin Healey 4
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
M stainless push button snaps for convt boot Austin Healey 2
T Stainless Steel Fender Beads Triumph 1
G Plasma Nitrated cali vs stainless caliper pistons Triumph 1
Stinger TR4/4A TR4A Stainless Trim Installation Triumph 5
Stinger TR4/4A TR4A Stainless Door Trim Question Triumph 5
Frank C. Stainless Steel Exhaust Austin Healey 6
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Stinger TR4/4A TR4A Trim Emblems Chrome Stainless Installation Triumph 3
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
I Chrome or stainless rivet source? Spridgets 21
M TR4/4A tr4a stainless fender trim? Triumph 3
R Stainless Steel Exhaust system Austin Healey 14
M TR4/4A tr4a stainless trim? Triumph 7
RJS Stainless Steel Bumpers Triumph 11
G stainless steel exhaust Austin Healey 14
T Recommendations on stainless brake lines Spridgets 13
T TR4/4A Stainless steel brake lines for a TR4a Triumph 12
T Regular vs stainless steel pistons for calipers Triumph 13
