BJ8 door hinge milling?
wangdango
The right hand door is tight on closing side and so much so it touches ever so much with the rear fender. The prior owner welded in new hinge pillars and the front and rear fenders line up perfectly. There is NO shims under the hinges and I thought about perhaps milling the hinge down a bit to get the door to close better. Anyone have any thoughts on this?
Sounds like a route I'd take to correct the gap. My only suggestion would be to only mill half (1/2) as much as you think you need on the first pass__and then reassemble to check results.
Take the same amount from both top and bottom hinges (if cutting on the pillar side) to avoid potential binding. If cutting from the door side (which is easier to cut aluminum) binding shouldn't be a concern.
Let us know how it turns out, because I'm pretty sure this has been brought up before, but not attempted.
Brinkerhoff
As well as give more gap at the rear removing metal from the hinge will also move the door forward the same amount ! Make sure you have enough gap to start with, so the leading edge of the door doesn't bind the fender when its opened.
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
LAW75 BJ8 Door Locks Austin Healey 2
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
H Door seals BJ8 Austin Healey 15
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
B BJ8 Door hinges Austin Healey 16
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
C BJ8 door strikers keep slippng Austin Healey 7
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
T BJ8 door glass replacement Austin Healey 4
B BJ8 door seal attachement point. Austin Healey 4
Jeepster BJ8 - Glove box door lock Austin Healey 3
D BJ8 Door Seal Orientation Austin Healey 6
M Bj8 door disassembly Austin Healey 5
bighealeysource DOOR ADJUSTMENT ON BJ8 Austin Healey 12
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
S BJ8 Glove Box Door Retaining Bolt Austin Healey 5
J BJ8 door latches Austin Healey 3
J BJ8- How is the chrome door top molding installed? Austin Healey 11
bighealeysource door alignment on a BJ8 Austin Healey 1
C BJ8 Door latch question Austin Healey 9
J Replacing door hing pin on 64 BJ8 ph I Austin Healey 2
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
Editor_Reid BJ8 Door Glass Austin Healey 6
P Removing BJ8 Door Panels Austin Healey 21
S BJ8 Door Moulding Installation Austin Healey 6
6 BJ8 Door Latch Austin Healey 3
tahoe healey BJ8 door trim Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
