BJ8 Glove Box Door Retaining Bolt
Scot
Guys,
While working inside my glove box the other day and I must have put too much weight on the door as it layed open.
The small chrome bolt that holds the slide(attached to door) to the inside of the box popped off. I tried to push it back on to no avail.
I can't find any kind of backing to this bolt either. Looks like it just press fits throught the cardboard liner and into a retainer hole.
Hard to even get a finger between the dash and glove box to feel the backing of this hole! Any ideas out there on how to reinstall it? Thanks!
Keoke
Hi Scot, it is not shown as a replaceable item in my parts list. However, if you remove the whole assembly from the car you may be able to repair it.
John_Progess
Scot,
I believe the "bolt" you are talking about is actually a rivit that is attached to a flat metal section with two holes in it. This piece of metal is then attached to a "L" bracket that is attached to the back of the wood dash with two wood screws. That is what is on my car which may or may not be factory. Use a mirror and flashlight and look behind the glove box and you should see the bracket. You should be able to drill and tap the rivit with something like a 4-40 screw. With the heater box in the way I don't think you would be able to attach the screw with removing the dash. You might also use a suitable sheetmetal screw as a temporary fix. Have a good day!
John
andybj8
Scot,
Heres some pictures of the slider / bolt and the rear bracket. There is a slot in the glovebox cardboard for the slider and bolt to be manually fed thru:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5128490
https://www.austin-healey3000.com/apps/photos/photo?photoid=5128512
The bolt seems to be fixed to a small zinc plated / chrome plated plate which is then screwed to the black L shaped bracket that is fixed to the dash.
I can not see enough to see if the bolt is held onto the smaller plate via a countersunk stud or welded. You will have to unscrew the black bracket from the rear of the dash and then unscrew the 2 screws that fix the 2 brackets back to back.
Hope that makes sense!
cheers Andy
S
Scot
Thanks Andy, nice close-up photos of the area in question!
Interesting that your L bracket back there does not have a pre drilled hole between the two screw points for the chrome rivet to snap into.
I wonder which is factory?
S Glove Box Lock - BJ8 Austin Healey 3
wangdango BJ8 Glove box lock? Austin Healey 1
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
bighealeysource BJ8 owners- glove box locks available Austin Healey 13
H BJ8 glove box lock Austin Healey 4
Jeepster BJ8 - Glove box door lock Austin Healey 3
6 BJ8 Glove Box Lock? Austin Healey 20
S BJ8 Glove Box Lock Problem Austin Healey 12
S Who sell the best BJ8 replacement glove box? Austin Healey 2
J Need a dimension on BJ8 dash glove box . Austin Healey 11
David_K BJ8 glove box lock Austin Healey 5
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
