Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ???
Jeffsbj8
Please tell me where I can find the key lock numbers for my BJ8 Door Lock ,Trunk & Glove Box locks ? I only have a key to the ignition, obviously the ignition is marked but where do I find the other lock numbers. I have a Heritage Certificate but no number on it either. What is the next step ?
thanks, Jeff
Keoke
Door and trunk lock handles should be marked on the square shank that extends into the locking mechanism.
In my case the trunk lock had a Mercedes Benz number on it but it was correct got it out of AU.
Others will chime in with additional data.
British_Recovery
Bronze
Jeff,
Originally the ignition and doors used the same key, and the trunk and glove box shared the same key (usually the smaller rectangle shape). If the ignition key doesn't work in the doors, something has been changed. Door locks are marked on the tumblers inside the barrel and the handle has to be off the door for access. Remove the 3 screws on the triangular plate to slide out the intermediate cylinder. Sometimes marked with a number, but it might not be correct. Lock cylinder can be released to the outside of the handle by depressing the 5 blades with a dental tool.
Good luck, Bob
J
Jeffsbj8
This weekend I will access the numbers, thanks so much for the advice. Then contact Triple C and get the long lost keys. Cheers, Jeff
L Where to find BJ8 Cam Spec's? Austin Healey 3
trrdster2000 GT6 Where to find the right tire? Triumph 8
zedvictor1 Where can I find the supporting vendors? FORUM Navigation Questions 1
R TR4/4A Where to find the chrome switch bezels? Triumph 6
HealeyDave Instrument gauge numbers by year - where to find Austin Healey 2
R Where to find a 55 100-4 Austin Healey 2
D TR2/3/3A Where can I find steering box bearings? Triumph 2
I How do I find where battery is being drained from? Spridgets 17
T T-Series Where to find strip for MG TF sidecurtain? MG 4
R Carb help, where to find it? Spridgets 4
S Need to know where to find info MG 1
D Where to find springs MG 8
G Where can I find the chrome "MG" air filters? Spridgets 4
sparkydave Where to find an inexpensive dial gauge Restoration & Tools 20
ekamm Where can I find #4 cup washer ? Triumph 6
R Where To Find Used Parts Triumph 17
C Where to find frames? Triumph 7
N Where can I find info on MG Midget engine numbers MG 0
N Where can I find info on MG Midget engine numbers Spridgets 6
germanmichel Where I can find a detailed frame Drawing ? Austin Healey 5
eejay56 Spitfire Where can I find a Spitfire 1500 shift handle Triumph 3
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
G TR2/3/3A Where can I find a complete TR3 engine parts book? Triumph 3
t8nwa where do i find a '80 softtop frame? Triumph 3
miranda Where to find the car number on a 100-6? Austin Healey 14
M Where to find "amber" fog lights? MG 2
AUSMHLY Where do I find the numbers on my car? Austin Healey 1
V Where to find an OEM hardtop? Triumph 2
L Where do you find "The Good Parts"? Austin Healey 12
svtmikey GT6 GT6 Paint - CODE 34....where can I find it? Triumph 15
R Where do I find? Spridgets 11
H Where can i find it? Triumph 3
S Where to find speaker grilles? Triumph 5
C where to find E type race cars ? Jaguar 5
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
