BJ8 Brake Lines
LAW75
Anyone knows what is the type, and are the lines painted any color, of concours-correct brake lines for '66 AH BJ8? Thanks.
Jerry
They are steel and were probably zinc coated originally. but most cars I have seen, they look like dark metal.
Legal Bill
I recommend buying a copy of the concours guidelines. The originals were plated steel and appearance is dull gray. Most of the tubes end in a double flare, but some may be the bubble flare.
C question on the front brake lines for BJ8 Austin Healey 2
D BJ8 brake master cylinder question Austin Healey 6
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
Marvin Gruber BJ8 brake booster Austin Healey 6
wangdango BJ8 brake reservoir? Austin Healey 7
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
H BJ8 Exhaust System and Brake Servo Austin Healey 16
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
Marvin Gruber BJ8 brake booster picture Austin Healey 4
Marvin Gruber BJ8 brake connectors Austin Healey 17
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
J Emergnecy Brake Cable Replacement BJ8 Austin Healey 4
P Brake boost repair, BJ8 Austin Healey 10
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
B BJ8 Rear Brake Questions/Advice Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
R BJ8 with servo...Brake travel issue Austin Healey 30
R BJ8 Brake Drum Removal Austin Healey 6
L BJ8 Brake servo Austin Healey 6
P BJ8 Brake Booster mount Austin Healey 9
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
T Soft brake pedal on BJ8 Austin Healey 3
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
S BJ8 rear brake drums Austin Healey 8
letemglow Brake master cylinder BJ8 Austin Healey 0
healeyneil Sticking back brake BJ8 Austin Healey 0
J BJ8 brake light not working? Austin Healey 2
C BJ8 brake fluid disappearing Austin Healey 11
C BJ8 brake servo options Austin Healey 5
J Late BJ8 brake rotor- thickness specs Austin Healey 5
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
WALTER BJ8 w/o brake booster? Austin Healey 4
J BJ8 Brake Booster Austin Healey 5
C AH3000 BJ8 Brake Caliper question Austin Healey 7
R 67 BJ8 Brake Light Switch Austin Healey 2
R 67 BJ8 Brake Fluid Resivor Austin Healey 6
R BJ8 brake calipers Austin Healey 14
S BJ8 Emergency Brake Lever Loose Austin Healey 1
D brake light problem 67 BJ8 Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
