BJ8 brake booster picture
All brake lines are run except for brake booster. Will be rebuilding it soon. Having trouble figuring out how to mount. I have the two triangled shaped brackets that go on the bulkhead but how does the booster mount to the brackets. Am I missing more brackets? Picture please!
Marv
RAC68
Hi Marv,
The long side of each of the (2) Girling Brake Servo mounting brackets are attached to (2) studs extending from the incline portion of the passenger side floor. The Servo is oriented with the air canister facing the engine and the smaller portion of the mount closest to the canister attached with to the hydraulic body of the servo with (2) bolts with the fender-side mount attached with (1).
Have fun,
Ray(BJ8P1)
From a bit further back; the frame rail is parallel with the bottom of the picture, and in the background, the starter is on the left, generator and engine mount pedestal on the right.
Clearly, this is the before picture ;)
Marvin Gruber
Thanks Randy, I kept trying to mount it straight and with lines on top. Its been 7 years since the last BJ8 I restored and I didn't take this one apart. Its missing a lot of little parts and hardware
Marv
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
Marvin Gruber BJ8 brake booster Austin Healey 6
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
BOBBYR BJ8 Brake Booster Austin Healey 13
P BJ8 Brake Booster mount Austin Healey 9
WALTER BJ8 w/o brake booster? Austin Healey 4
J BJ8 Brake Booster Austin Healey 5
LAW75 BJ8 Brake Lines Austin Healey 2
D BJ8 brake master cylinder question Austin Healey 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
wangdango BJ8 brake reservoir? Austin Healey 7
H BJ8 Exhaust System and Brake Servo Austin Healey 16
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
Marvin Gruber BJ8 brake connectors Austin Healey 17
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
J Emergnecy Brake Cable Replacement BJ8 Austin Healey 4
P Brake boost repair, BJ8 Austin Healey 10
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
B BJ8 Rear Brake Questions/Advice Austin Healey 4
R BJ8 with servo...Brake travel issue Austin Healey 30
R BJ8 Brake Drum Removal Austin Healey 6
C question on the front brake lines for BJ8 Austin Healey 2
L BJ8 Brake servo Austin Healey 6
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
T Soft brake pedal on BJ8 Austin Healey 3
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
S BJ8 rear brake drums Austin Healey 8
letemglow Brake master cylinder BJ8 Austin Healey 0
healeyneil Sticking back brake BJ8 Austin Healey 0
J BJ8 brake light not working? Austin Healey 2
C BJ8 brake fluid disappearing Austin Healey 11
C BJ8 brake servo options Austin Healey 5
J Late BJ8 brake rotor- thickness specs Austin Healey 5
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
C AH3000 BJ8 Brake Caliper question Austin Healey 7
R 67 BJ8 Brake Light Switch Austin Healey 2
R 67 BJ8 Brake Fluid Resivor Austin Healey 6
R BJ8 brake calipers Austin Healey 14
S BJ8 Emergency Brake Lever Loose Austin Healey 1
D brake light problem 67 BJ8 Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
