TR2/3/3A head gasket... which way up?!
Dr_Mike
Moss 690-022. flat on one side, embossed on t'other, but which way up? No markings. Moss tech thinks the flat side is up. Should I use Permatex copper spray if I can get it here in outer Mongolia (aka rural BC)? Rebuilding a broken engine from scratch is such fun: but I need a helper to lift the head safely! But I am getting there.
RandyInUtah
Member
I have always placed the side with the crimps up toward the head and the flat side down on the deck of all engines that i have rebuilt regardless of the make of the auto. Perhaps someone with a gasket which is marked as to which side should be up will advise as to the crimp or flat side of the gasket.
TR3driver
Great Pumpkin - R.I.P
According to the factory, either side can be up. There was an early production modification to allow that (note the redundant hole for the oil passage to the head).
My preference is to install the flat side down, but I don't know that it makes any difference.
The book says to use "jointing compound" (the TR3 manual specifies Wellseal or equivalent). But my experience has been that, if everything is right, it will seal fine with no coating, and if something is wrong, coating won't help. So I make sure the liner protrusion is between .004" and .0055" on both sides, then install it dry. I learned the hard way to check both sides; spent a long time fighting blown head gaskets before I discovered I had a block that wasn't machined quite right. Oddly enough, I discovered the same thing with my current TR3, so I suspect it was common at least in the early days.
Dr_Mike
Thank you both for your replies. I am afraid that I am less sure about the part number. The gasket came out of an unopened pack of gaske=ts labelled 691-001, which is a lower gasket set made by Payen. (t may have been stuck in there for shipping.
Any way. it seems a lousy fit and , to my mind, would quickly blow out as it looks a bad fit. All cylinders look much the same. I shall try to add photos, and talk to Moss!
TR3driver
690-022 should be the cylinder head set. Did you get the rest of it? For sure, the Payen lower end set does not include a head gasket.
Those "wings" around the cylinders are the standard Payen pattern. I'm not sure why they are there, but Payen was considered one of the best TR head gaskets for a long time. Payen quit making TR2-4 head gaskets a few years back, but I understand another company bought the tooling and started making them again.
https://www.bpnorthwest.com/triumph...d-gaskets/head-gasket-german-tr3-to-tr4a.html
Dr_Mike
Thanks again. The Lower gasket set says "made in Italy": on a sticker. So that is before the German company took over.(?) The 690-022 number was our best guess since there was no visible number and it must j[have been repacked by the dealer I see that the NW parts head gasket also looks a bit eccentric. so i will take your reassurance and install it. And pray. lots.
charleyf
After having a head gasket start leaking at the rear of the rear cylinder. I realized that if you have the head gasket with the seam side down it allows the water to work on the seam. In my case the seam eventually allowed the water to get into the rear cylinder. If you look at the head in that location you will note that the head has only a small hole for the water, while the block has a large hole for the water. So to me it makes sense for the seam to be up against the head and the flat side to be against the block.
Seems like I did eventually find a gasket that was marked in this fashion. But I have not seen any since. There was a thread on this forum not to long ago where the consensus seemed to be to use Copper seal on the gasket as well.
Charley
TR4nut
Regarding the gasket picture a buddy of mine after a couple of failures switched from the Payen oval shape to another brand - I think the Lucas high performance one BPNW has was it. The fit to the liners was much better.
TR3driver
I don't think the German company is allowed to use the 'Payen' name. Apparently, Payen (now part of Federal Mogul) still makes the conversion set (EC510), they just quit making head gaskets when the tooling wore out.
(This link probably won't work, but it shows the conversion set listed on the Payen web site)
https://fmecat.com/selProd2.asp?mak...&litre=2.2&prdgrp=4&langID=1&TsVer=&engseal=1
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
DrEntropy MGB Head gasket R&R goes on... MG 13
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
R BJ8 Cylinder Head Gasket Austin Healey 38
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
KVH General Tech Head Gasket Triumph 10
RJS General TR Head Gasket Test Fit Triumph 5
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A Head gasket sealer question Triumph 7
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
