copper head gasket
Hairyone
Are these worth fitting during a re-build?
I'm gathering parts to build up a 1275 road engine for my frogeye. It will be slightly tweaked "warm cam, 1.5 ratio rockers & Vizarded head & HIF44"
I don't know what cam yet, I'm reading that section of the book now. I'm not planning on a screamer of an engine, but low down grunt.
I've got myself a "1275cc UNLEADED Cylinder Head 12G940 Big Valve 33.3 x 29.3mm 17L4" to fettle.
Anyone had any experience on such a cam?
:thirsty:
now off for a warm beer, yum.
Woblynne
Member
Hi, I would go for the Metro turbo gasket (its the black composite one). I used one on my Midget (HIF44, +30, LCB/RC40, MG Metro head 80bhp at the flywheel) and it hasnt failed me yet!!
I dont have any personal experience with cams but with time spent on a few A series forums, the SW5 cam pops up an awful lot, others that also feature heavily are the Kent 266 and 276.
Based on what I've read whenthe time comes I'll more than likely go for the SW5
"Big Valve 33.3 x 29.3mm", I thought that these were the standard valve sizes?
If you can find one go for the head from an MG Metro as it has 35.6 or 36.5 (can never remember!!)inlet and 29.3 exhaust and as a bonus if you can get hold of a late MG Metro one it would be unleaded (I am told that a good sign for unleaded heads is that the car has the fuel filler cap higher up on the car)
HTH
Mark
spritenut
I agree with Woblynne.
The only head gaskets I have ever blown were the copper ones.
I did blow 1 composite head gasket but never the black one.
BuggerAll
yep, the TAM 521 black gasket, have one in my hot 1275 BE (67 RWHP) with alloy head, works just fine. Also my two cents - Kent 266 is a very fine camshaft. I'm also using the HIF 44, plus LCB header, it's a great combination.
Hairyone
Hairyone
Many thank all.
Won't be using a CU gasket then.
CAM; yes I've heard good things about the SW5 cam, dam good price too:
£235 of our UK pounds for:
* Steel billet camshaft
* Cam followers
* Oil pump
* Lock tab washer
* Alloy vernier duplex chain
* Timing disc
They do a high lift kit with springs & 1.5 ratio rockers also but I'm waiting for a price on that.
Was looking at the Kent 266 and 276 also, so a little undecided yet.
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
K Installing Head bolts and copper gasket Triumph 12
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
Morris Copper spray and head gasket instructions??? Spridgets 5
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
davelgee copper head gaskets? Other Cars 2
T head gaskets?-copper of steel? Triumph 4
Z Copper spray and coated head gaskets? Triumph 0
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
TomMull Copper nickel lines again Restoration & Tools 0
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
glemon General Tech Nickel Copper Brake Lines Triumph 10
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
NutmegCT T-Series the copper pipe? MG 19
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
M brake pipe copper straps Spridgets 19
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
D Copper core plug wires MG 3
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
