TR6 tr6 - really dumb dash question
G
OK, so I need to remove the heater knob on my TR. It looks like it should just pull off. I don't see any retaining screws or latches. I tried pulling gently then in frustration a bit less gently, but it just sat there looking at me, making me madder and madder.
Before I adopt the brute force and ignorance approach, am I missing something stupid, or is it a straight friction fit and I need to use a bit more enthusiasm. The manuals are unclear (to me).
I already feel like an idiot for asking such a dumb question so be kind /ubbthreads/images/graemlins/confused.gif
On the bottom side of the knob where the black plastic covers the metal shaft there is a teeny tiny hole. You really have to contort to look underneath, and it's close to the flat part of the knob that you pull on, so it's easy to miss at first glance. If you insert a small nail or very small screw driver into that, it releases a retaining spring. (I can't recall the exact mechanism, but it's easy to figure out once the knob is off). I recal you need to keep pressure with the nail as you slide it off. Maybe I'll go try it again to refresh my memory!
Alas, I have actually seen some aftermarket, original style control knobs and control shafts for various TR6 switches that actually have a fake hole, no latch and drive on with friction. Whoa to the poor cluck that has to ever remove one. Check before you install one of these abominations. Right up there with the bonnet release cables everybody now sells. Pure crap.
Bill
I got a new choke cable a few years back from TRF, looks like the knob is completely glued on or something. Hope I don't ever have to take it off, only way seems to be to unhook it from the carbs and pull the whole thing back out through the dash hole.
John is correct, there SHOULD be a small hole on the understide of the heater knob. The trick is to push the spring loaded ball that fits into that hole in while tugging on the knob to release it. It's easier said than done, but if the ball is still in plce, that's what is holding the knob on.
Mark
1970 TR-6
PC A really nice TR6 and a ? Spotted 2
Brosky TR6 Really BIG Brake Kit for TR6 Triumph 15
Brosky TR6 TR6 Oil Leak at rear of head - [not really] Triumph 0
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
