Prothane bushings are really nice to work with,,,,
tdskip
....but I think I stll have their lube/grease stuck to my fingers...
(yes Drew, believe it or not I actually worked on the Bugeye yesterday. :whistle: )
drooartz
I'm proud of you, Tom!. :smile:
T
tdskip
Drew - sit down now, but I even finished getting the rear suspension back in place including new axle straps.
I wasn't happy with the fit from Moss so I removed the original metal sleeves and put them in the new Moss ones... Just seems like a better fit and solution for longevity.
drooartz
That's excellent, Tom. Now you're making me look bad. :smile:
Platinum
He's even done a comp test on that lump of an MGC in the mean time!!!
Better pick up th' pace, Drew...
at least go out an' POLISH somethin'! :smirk:
T
tdskip
Doc - don't forget to add that I pulled the MGC radiator and would have had the brake & clutch MCs out if the MGB pedal box wasn't designed by some evil genius....
Come on Drew - get on it! lol
Platinum
:lol:
I had less intel when that was posted, Tom.
drooartz
DrEntropy said:
Better pick up th' pace, Drew... at least go out an' POLISH somethin'! :smirk:
At least the pace can't slacken, as there hasn't been any!
Too busy now with day job and the winter gig season (in a ski town, winter's the busy time). Making hay while the sun shines. Still, I pull into the garage every day and see that little car just waiting for me. Give me maybe 3 weeks for the rush to die down, and I'll be back at it.
I will drive it this year. 'Nuff said.
Platinum
I'm jus' givin' ya grief fer nothin' Drew, go fer th' money. :wink:
drooartz
It's killing me though, Doc. I've got my motivation back, but no time or space to do anything about it. Stupid winter.
jerrybny Prothane Bushing Installation Triumph 6
jerrybny Prothane Polyurethane Bushing Sets Triumph 9
vping Prothane, Nylatron or V8? Taking Recommendations. MG 13
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
KVH General Tech HS6 Carburetor Bushings Triumph 10
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
R TR6 Lower A-arm trunnion bushings Triumph 18
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
Upland SuperPro trunnion bushings Spridgets 0
R TR2/3/3A Upper Wishbone Bushings Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
D TR2/3/3A steering column bushings Triumph 8
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
S TR6 steering column bushings Triumph 5
N Top link offset bushings?? Spridgets 6
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
B TR2/3/3A Inner wishbone bushings Triumph 5
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
Got_All_4 General TR Anyone running superpro bushings? Triumph 3
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
M XK140 Sway Bar Bushings Slipping out of Brackets Jaguar 1
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
S King Pin Bushings Austin Healey 1
K TR2/3/3A Silent bloc bushings in the drag link. Triumph 2
C TR4/4A TR4A Differential Mounting Bushings Triumph 6
