Question regarding NOS vs New rear leaf spring bushings
shortsguy1
Hello-
Thanks everyone for your help with my radiator pressure cap question. I was hoping I could bug everyone for one more piece of advice.
You may recall my thread a while ago where I was asking for advice on vendors of high quality leaf springs:
https://www.britishcarforum.com/bcf...ent-experiences-with-rear-leaf-spring-vendors
In the end, I was able to buy new, but very old leaf springs via Ebay. They were sold by Moss (as they have a Moss part number on them), but were Made in England and are identical in appearance to the current rear leaf springs sold by Denis Welch. I don't know their exact age, but Moss has been selling India-made springs for a while now, so my "new" springs must be pretty old.
I was hoping to get advice on replacing or keeping the bushing that comes with those springs. It appears to be two sleeves of metal separated by a thin (maybe 1/8") of rubber. Here is a picture of the part in question:
https://www.ebay.com/itm/AUSTIN-HEALEY-3000-MAIN-LEAF-SPRING-BUSH-SPRING-EYE-BUSHES-X4-/301253194341
So if the springs I bought are 20 years old (but unused), would you recommend replacing this bushing before I install them? I have had bad luck with modern rubber on many parts of my old Mercedes, and I wasn't sure if modern Healey rubber parts also suffer quality issues. Perhaps 20 year old rubber from England is better than brand new rubber from CountryX. It certainly seems fine in the NOS springs, but I cannot really load them in my living room like they will be loaded on a car.
I understand the recommendation is to replace as many rubber parts as possible when doing this sort of work, but in my case, it wasn't clear what is the best solution.
Is this bushing a common failure location where the rubber tears/collapses/degrades? If that part is relatively robust, I will probably just stick with the bushings that arrived in the NOS springs. Thanks for your advice.
Keoke
Spring bushings are a common failure item where the rubber tears/collapses/degrades.
Additionally, I just would not trust 20 year old rubber it could be as hard as nails.:encouragement:
Patrick67BJ8
I totally agree! Been there done that with NOS rubber parts.
jlaird MGB This weeks werd question regarding steering racks. MG 3
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
me61ic Question regarding BJ7 Subframe Austin Healey 16
ShawnC_at_Moss Question for you Bugeye guys regarding trunk side panels Spridgets 20
J Question regarding Bugeye tach and related topics Spridgets 8
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
angelfj1 Question regarding eBay photos Triumph 16
angelfj1 Question regarding ratchet/sockets Triumph 13
B TR6 Follow-on question regarding new TR6 tires... Triumph 5
soren_ak question regarding import from CUBA Other Cars 8
soren_ak question regarding moving a car from England to DK Austin Healey 2
M Question regarding the forum MG 15
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
